Browse Forums Building A New House 1 Mar 08, 2010 9:38 pm Hi all, I want to make the following changes to windows and doors in a Project home house plan. I have sourced the cost price of these changes from a window supplier, but understand that the builder will add a little on top for these changes. In preparation for my negotiations, I wondered how others were charged for similar modifications. Were they charged a reasonable amount, or, is this one of those areas where builders make good money on modifications to the standard plan? Does a larger window require more building frame reinforcement? Does a smaller windows cost get equalised by the more bricks that are required? Thanks in advance, Regards,Alf Windows: • Increase window from 1818 (SFS) to 1827 (FSSF) Swap: • Slide window 1809 (SFS) to 0621 (FSSF) set high on west face wall • Slide window 1818 to 1818 double hung Add: • Study window: 0621 (FSSF) • Laundry: 0615 (SFS) Doors: Swap: • Bed1: Slide window 1809 (yes window) to 2112 sliding door • Laundry: 2115 slide door to 820mm standard external door • Bath: standard internal entry door to cavity sliding door • Relocate position of internal entry doors to B1 and B2 Add: • 820mm standard external door at rear of garage Built Hallmark Home in SE Queensland - modified Flair 181 - no A/C: n/e orientation - 9 foot ceilings - copius insulation - loads of windows - fresh breeze - home... Re: Cost to modify window/door sizes in project homes??? 2Mar 08, 2010 9:54 pm Also, forgot to ask this: if you raised your ceilings, did you raise your window and door heights? If yes, why? Built Hallmark Home in SE Queensland - modified Flair 181 - no A/C: n/e orientation - 9 foot ceilings - copius insulation - loads of windows - fresh breeze - home... Re: Cost to modify window/door sizes in project homes??? 3Mar 08, 2010 10:40 pm We changed one window and swapped one for a sliding door - contracts were signed two years ago, so these prices are a bit out of date.... We swapped: - a sliding aluminium window (can't recall the original size now) for a fixed one 600 high x 2700 wide at 1650 above floor level. There was no charge for this one. - a sliding aluminium window for sliding door 2100 x 2400 - cost $290. We had a lot of other window alterations, but they all involved timber windows or bifold doors, so the prices aren't relevant for your purposes. We raised ceiling height and also raised internal door heights - we saw no need to change window heights, and external doors stayed as standard. We could have gone for a higher front door, but opted for a highlight instead, which avoided it looking stunted. I just preferred the extra height of the internal doors - we thought the huge gap between standard door frames and 2740 ceilings looked silly in the house we rented. Re: Cost to modify window/door sizes in project homes??? 4Mar 08, 2010 10:52 pm Hi Kek, thanks for your reply!...It seems that the prices were reasonable. I am meeting on Wedensday with the builder, so thanks... We have lived in an old queenslander with 11 foot ceilingsfor years. For the first time ever, I just looked at the distance betweend the doors and ceiling height. hmmmm...... Built Hallmark Home in SE Queensland - modified Flair 181 - no A/C: n/e orientation - 9 foot ceilings - copius insulation - loads of windows - fresh breeze - home... Re: Cost to modify window/door sizes in project homes??? 5Mar 08, 2010 11:49 pm We've kept standard door height with 9 foot ceilings. We did the same thing in our last house and it looks perfectly fine. Either way will look fine. Re: Cost to modify window/door sizes in project homes??? 6Mar 09, 2010 6:42 am The only disadvantage to raising door height is if you have double doors. Unless you're very tall, you won't be able to reach the locking bolt at the top of the fixed leaf without a stepladder. We have two sets, but since we rarely open the fixed side anyway, it hasn't been a problem. I have a box of quality drill bits that seem to be new but their engraved sizes covered by rust ,,,,I tried to sand them to see their sizes but still I am finding… 0 1441 I have been looking into getting quotes for a reno I am doing shortly. I have been looking at Trend and Wideline for both windows and doors. I did enquire with Vista but… 0 6167 Hi All, I'm new here! I'm in a block of 4 apartments (Waverley council) and looking to change a window to a sliding door. The window faces an enclosed garden (with a… 0 5540 |
