Browse Forums Building A New House 1 Mar 08, 2010 8:02 pm Hello All, We will be doing our Pre-handover inspection with our builder tomorrow; and due to Yesterday heavy rain at Melboune, we've noticed that water somehow had gotten into the Porch's ceiling evidenced by the watermarks building up along the porch's ceiling . Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I went up to the roof to try to understand how water got in and discovered that there was an opening on the roof( about 50sq cm cavity in between the front eaves and side roof) - Is this normal? i can even see wire running through and the frame from the hole. I supposed that's how the water got in Portico Roof Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Joint of front eaves and side roof Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hole Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hole Enlarge Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I can't understand why independent inspector did not pick up on such an obvious structural issue - can anyone please advise me if this is normal or am i misunderstanding the structural requirements? Appreciate if anyone can shed some light. thanks Jo & Tina How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 6047 There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2476 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17254 |
