Browse Forums Building A New House 1 Mar 08, 2010 7:51 am OK so we are at the stage of final inspections. PD did their 'independant' inspection Friday and we are waiting on a date to be set for PCI. As most of you would have heard there were severe storms in Melb on Saturday. Well we have a few broken/missing roof tile. A big leak around one of our ducted heating vents. 3 cracks that are very wet in the lounge ceiling and one the same infront of our pantry. We couldnt see into every room of our house. So they are the bits we know of. Suerly this means there is some serious water damage in the roof and effecting the insulation and plaster ceiling. Probabyly areas fixing the soundproofing/insulation we have in the entire homes wall cavities. HELP what needs to happen to fix this mess? Can they just patch the cracks caused by the water and repaint the ceiling or do they need to replace the damaged plaster and repaint? Do they need to remover insulation and soundproofing that has gotten wet? Thanks for your advice!!! Re: Melbourne storm damage, HELP 2Mar 08, 2010 8:07 am That must be heartbreaking. So close and now problems. Sorry to hear that his has happened to you. Unfortunately, I can't help you with your question, but this will at least bump the thread higher for you. Pfiff Finally making progress again, with a clothesline (yippee) and some much needed little things being attended to over the holidays. 40 C on New Year's eve? We love our a/c! Re: Melbourne storm damage, HELP 3Mar 08, 2010 8:17 am LOL thanks. We have a baby due 11th April so we were hoping to move into in late Jan but when the builder needed to fix so much other stuff and we got delayed we decided to move after baby is born. So yes although we are so close the time delay doesnt worry us too much more the ongoing probs we are going to have Thanks for the bump up! Re: Melbourne storm damage, HELP 4Mar 08, 2010 10:15 am I think it is probably better that it happened now before handover... No idea what will be replaced or repaired, but better that the builders insurance cover it than your own! But how very frustrating =\ Just wanted to send hugs, and all the best for getting through your birth with as little stress from your builder as possible! Re: Melbourne storm damage, HELP 6Mar 08, 2010 10:50 am The damage may not be as bad as it seems, and can probably be fixed pretty easily. Insulation batts can be replaced, plaster may be OK once dry and repainted - even if patching is required (cutting out damaged sections and replacing the gyprock sheeting, then plastering over joins), that can be done in a couple of days. The bigger problem is that they've most likely had numerous sites damaged in the storms, and so has every other builder - plus large numbers of established homes will have damage too - so tradesmen are going to be booked solid and might not be available straight away. You may be looking at a bit more of a delay, unfortunately. Fingers crossed it can be fixed quickly for you. Get straight onto your SS - he'll probably be aware of it already, but it doesn't hurt to get in quickly. Squeaky wheels and all that. Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7816 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6846 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10479 |
