Browse Forums Building A New House 1 Mar 07, 2010 8:25 pm We are in the process of building and need to decide on colours for the render. I want our house to look like the picture in the URL however we have modified a few colours such as garage and front door in the picture. So I need someone to tell me the white? Beige? Greyish colours that are in the picture OR closest too as there are just so many similar colours out there its mind boggling. Thanks Oh and the other problem is making sure these colours go with the downpipes of 'surfmist'. http://bellmarch.com.au/Product_Detail. ... =13&Prod=3[/url] Garage Door: Monument Roof: Tiles: Barramundi (dark) Windows: White Gutters: Monument Downpipes: Surfmist. Front door: Monument (Similar) Re: Cant find the right 'White' for rendering!!! 3Mar 08, 2010 9:15 pm I had this problem ended up going surfmist to match the roof as I wanted a full white effect on the front of the house, to highlight the timber deck. I am really happy with the effect. I think white is the hardest colour to get right. Cheers Lou http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys Re: Cant find the right 'White' for rendering!!! 4Mar 09, 2010 10:00 am Thanks I seem to like the Beige Royal. I might grab a sample pot and take a look. The other option is surfmist. Did you use fulls strength surfmist and do you have a picture of your house? Re: Cant find the right 'White' for rendering!!! 6Mar 09, 2010 5:34 pm KLB002 Thanks I seem to like the Beige Royal. I might grab a sample pot and take a look. The other option is surfmist. Did you use fulls strength surfmist and do you have a picture of your house? We use full strength surfmist,I will upload some pictures on the blog (link below), the garage has not been painted yet, but the other side of the house has. Cheers Lou http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 3357 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 4289 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 4348 |
