Browse Forums Building A New House 1 Mar 04, 2010 4:16 pm hello people...well we had second inspection for OC and...we need to fire proof the front door. yes, the first insepction missed that. anyway it would be interesting to see what options we have. we have really nice doors which we dont really want to cover with mesh etc. fire proof paint maybe? if you could post your pics how u have done it would be great. Re: fireproofing entry doors 2Mar 04, 2010 8:10 pm This is exactly what we're dealing with right now. We've been stuck in council for entirely too long, and it's all due to our proposed bifold doors. While we don't have an approved solution yet, it's likely soon. What council, the RFS, and our bushfire consultant have said is that are makers of doors that have been proved to be acceptable up to Level 3 bushfire zones (Trend Doors). Seeing as our builder doesn't work with Trend, we're required to change the wood we use, then use a special varnish that helps with the "radiant heat flux". Merbau wood is considered to be a hardwood, and satisfies requirements of Level 3 bushfire. Unfortunately if you're above lvl. 3, not sure what's required, but hopefully you're not... Stefan Building the M3tr!con Liberty 42 at Stonecutters Ridge. The New Build Blog - "Life, In Progress." Stonecutters Ridge Community Website | My photos I ran into trouble finding a lock that would fit my particular door, like your situation with your pivot door. I wanted a safe lock that couldn't be messed with easily. 4 25705 Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 4607 I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an… 0 1506 |
