Browse Forums Building A New House 1 Feb 20, 2010 7:41 am just had our inspector in - the ceilings are too low - definitely not as per contract by about 65mm in some onf the bedrooms I dont want them to take them down and redo as we are already 10 months late. What can i do? how much compensation? Re: ceilings are too low 2Feb 20, 2010 8:14 am Hi welcome to Homeone, what a shame your first post is about a problem in your build. I'm not sure what height your ceilings are supposed to be, but if you didn't increase the height, and just have the standard ceiling height (2400mm), you might not get a choice but for them to redo them. I'm sure there is a standard/building code that the ceiling height must be, and anything under that does not comply. In my experience - my parents doing a reno atm, they had to dig down to increase a ceiling height in a couple of bedrooms to met the regulations. Ok - just did a quick google search - and this came up in the Building Code of Australia "in the BCA is: Ceiling heights must be not less than 2.4 metres in a habitable room" Hope it helps. Bel Still not in. Don't ask!? Re: ceilings are too low 3Feb 20, 2010 8:49 am Hi, Sorry to hear about the ceilings! I could understand not wanting to rip them down and having to wait again but I guess it depends on if they are lower than the 2.4 in which case they will have to redo them However, if you upgraded them and they are still over the 2.4m but not as high as you paid for I would ask for the money back on the upgrade of the ceilings. If they are lower than the 2.4 maybe try and seek compensation for the time it takes for then to replace them. RHI - BALDIVIS PERTH 2005 Bought/Finished WA Housing Centre Home 2010 Building the Benchmark with REDINK Homes in The Avalon 2013 Building the Michigan with Cont3nt Living In Highbury Estate! Re: ceilings are too low 4Feb 20, 2010 9:48 am If you asked for an upgrade and they didn't build as per the contract for this, I'd not only ask for the upgrade money back but I'd try and estimate just how much having high ceilings would be worth if you were to sell the house. ie: what's the real value of having high ceilings. Maybe ask a local real estate agent? What a pain Good luck Re: ceilings are too low 5Feb 20, 2010 9:50 am our contract says 2440mm some of the frame to ceiling heights are 65mm out taking a generous 25mm for floor and ceiling coverings this is still significantly not as per contract. Re: ceilings are too low 7Feb 20, 2010 10:54 am saxien When you say only some of the bedrooms are too low, what is the height of adjoining rooms? , with a frame all wall plates should be a similar height Do you mean me? That example is not with a new build, but a reno like I said - actually converting the old garage into a bedroom, bathroom and rumpus. Still not in. Don't ask!? Re: ceilings are too low 8Feb 20, 2010 10:57 am bel saxien When you say only some of the bedrooms are too low, what is the height of adjoining rooms? , with a frame all wall plates should be a similar height Do you mean me? That example is not with a new build, but a reno like I said - actually converting the old garage into a bedroom, bathroom and rumpus. Sorry, I was replying to the original poster with a new build problem Re: ceilings are too low 10Feb 20, 2010 11:44 am I second Rowenas point of finding out what money you would of missed out on if you would of sold the house with high ceilings!!! RHI - BALDIVIS PERTH 2005 Bought/Finished WA Housing Centre Home 2010 Building the Benchmark with REDINK Homes in The Avalon 2013 Building the Michigan with Cont3nt Living In Highbury Estate! Re: ceilings are too low 11Feb 20, 2010 1:29 pm lodnonwelsh our contract says 2440mm some of the frame to ceiling heights are 65mm out taking a generous 25mm for floor and ceiling coverings this is still significantly not as per contract. Need to be rectified to bring to standards. It's not a matter of compensation for what would of been, as its classed as uninhabitable so technically no longer a room. Have to say in all my years in the building trade this is very unusual for a builder to get this wrong. Is there more to this story? Landscape Design & Construction http://cherub.squarespace.com/ Re: ceilings are too low 12Feb 20, 2010 2:41 pm HI, I must agree with the last post some what. Compensation may not be the big issue. The big issue is that the certifier be it either council or private may not give final or occupation certificate and therefore you will not be able to move in. I would speak to the certifier asap. By the way I am a builder and this is the first I have heard of this. Is it a project home or a private builder? Good luck Re: ceilings are too low 13Feb 20, 2010 7:04 pm large builder - have had plenty of problems with them 10 months later now our inspector says he has seen it 3 times in the last year have spoken to the surveyor - he wasnt not aware of the issue!!! well inspected!!! Thanks! I'm spoke to the builder I'm not sure if this is all true but basically went along the lines of they considered all options and if I was to compact and fill it… 2 6391 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39474 I was quoting framing timber sizes from Australian Standard AS1684.4 Table A13 for 2700mm wall heights Tile Roof, single storey. This Australian Standard doesn't refer to… 8 7308 |
