Browse Forums Building A New House 1 Feb 18, 2010 2:07 pm We're looking to build with BigM, a design that has the Butlers Pantry connected to the Laundry, (ie enter Butlers Pantry from Kitchen, then thru another doorway into laundry) and the laundry has it's own access point from the passage. We're thinking about combining the two into one large area so the only access to this area is via the kitchen. We were wondering if anyone else has considered this and what are your thoughts? We're happy we'll get one large pantry/laundry work area, however the only access will now be via the kitchen. We've seen some designs that are similar but would like to know people's actual experiences.
With the fridge inside the pantry: http://i831.photobucket.com/albums/zz23 ... aundry.jpg and with the fridge in the kitchen: http://i831.photobucket.com/albums/zz23 ... undry2.jpg Re: Ideas on combining Butlers Pantry and Laundry into one? 2Feb 18, 2010 2:22 pm Will you have windows or access to outside via the laundry part?? We had a house where you could only access the washing line by going through the house, and I would say, it's much more convenient having direct access from the laundry to the outside. If thats not the case, then I don't see it would be a problem. Alot of laundries are off kitchens, so all you'd be having is an extra bit for the pantry. Re: Ideas on combining Butlers Pantry and Laundry into one? 3Feb 18, 2010 2:32 pm Sorry, should have mentioned that! Yes, we're keeping the external door to the laundry and the window over the bendch in the butlers pantry section. Re: Ideas on combining Butlers Pantry and Laundry into one? 4Feb 18, 2010 2:35 pm Looking at the plan and being a lazy housewife I would think it would be a pain to come downstairs and then have to walk around the kitchen to get into the kitchen with the dirty washing. Then when it was ironed / folded same thing again - back through the kitchen to get around to the stairs to get back upstairs. Is there anyway you can still keep the access close to the stairs for ease of access? A laundry chute would help the dirty clothes aspect but not the clean clothes return (the main thing I hated about two storey houses - know why Americans have an internal laundry upstairs in most new homes!! But then again they use a drier for everything which is bad bad bad) Some things are worth waiting for. Re: Ideas on combining Butlers Pantry and Laundry into one? 5Feb 18, 2010 2:37 pm IMO i would be a little concerned having the pantry & laundry linked considering the heat/water vapour from dryer would be going straight into your pantry where food stuffs are kept. I think these two areas should be kept seperate. If laudry has it's own entry way then i would close off pantry. Haven't seen design tho so only guessing, maybe if you could post a plan we could get better idea??? Cooper's Build - Perth NOR viewtopic.php?f=31&t=30525 Prelim- mid Sept 2009, Pre Start 2 Feb, Siteworks- 21 April 2010, Slab- 10 May, Deliveries- all by 26 May Bricking- 28 May - 26 June, Roof complete 5 Aug, Float 28 Aug, Lock up 16 Sept Cabinets 1 Oct, Tiling 22 Oct, PCI 18 Nov, KEYS 3 Dec 2010 MOVED IN 17 DEC 2010 Re: Ideas on combining Butlers Pantry and Laundry into one? 6Feb 18, 2010 2:39 pm Hi, Our designers put that idea to us as well. Our BP and laundry are right next to each other. I rejected the idea because then you would always have to take your laundry baskets through the kitchen and pantry to get to the washing machine (I know many laundries are off the kitchen, I just don't like it personally) but also it meant that any moisture from the washing machine and dryer was in the same room as the pantry with possible dampness around the food and groceries. I know you can vent dryers outside, which we've done in our current home but I still find it's quite damp on the walls and cupboards in the laundry on many occasions. I want to avoid that in the pantry so I've asked the rooms to be separate. Personal view really. ... Build thread: viewtopic.php?f=31&t=34120 Handover 23 Dec 11 Squatting 21 Dec 11 Fixed 12 Oct 11 Plastered 31 Aug 2011 Framed 7 June 2011 Site Start 7 Feb 2011 Land Titled 18 Jan 2010 Land Deposit 25 Jun 2009 Re: Ideas on combining Butlers Pantry and Laundry into one? 7Feb 18, 2010 3:41 pm Thanks for all your updates - they're really appreciated. Since I'm new to posting to this site, I'll try and upload an image of the floor plan for the butlers pantry/laundry! I know a lot of UK homes have the laundry as part fo the kitchen; I suppose to save space. We're planning on having a front load washer and dryer in the laundry with the dryer vented externally so moisture won't be an issue. It also frees up a lot of bench space too. We gain a lot of floor space combining the two areas and agree that having to trundle a basket of washing thru the kitchen is something we'd have to live with, we're hoping we can have a laundry chute from upstairs to avoid this. Re: Ideas on combining Butlers Pantry and Laundry into one? 8Feb 18, 2010 7:37 pm When I was living in UK the washing machine was next to the dishwasher in the kitchen, as the whole flat was about the size of a double garage anyway I think you left a comment on my blog, so I post a pic and blogged about it here http://tim-and-tina.blogspot.com/2010/02/day-58-first-floor-wall-framing-98.html Knockdown and rebuild - building Metr1con Nolan 41 (43) @ http://tim-and-tina.blogspot.com! http://www.verdantdental.com.au I visited a relatives house and he went with sink in kitchen and butlers, dishwasher in kitchen and butlers and has crockery spread out between the two areas depending on… 2 44072 Hi everyone, Newbie renovator here, after some advice for combining our family room in the picture and the alfresco and make a larger family room. There is a flush sill… 0 4891 Any electricians here please help. 1) Will the Fan need separate switch to ON/OFF/Speed eventhough it comes with Remote 2) how about… 0 1215 |
