Browse Forums Building A New House 1 Feb 12, 2010 12:25 pm First off, I found this forum by googling "RedInk Custom 5000" and found a few posts relating to the same house I am building with RedInk. I have been kept busy reading posts here and decided to also share my experiences (and photos) with you all.. I bought my block (located in Mandurah, WA) in late September 2009, found a house plan that would suit, signed all the papers and quickly applied for my first home owners grant ($21,000 woo hoo!). I didn't spend much time looking around for 'the perfect' house since I will be the only one living there and I felt the size of this house was more than enough for me. House Plan (Flipped from Original and Modified Slightly) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Progress so far... 22nd Dec 2009 - Pad cleared Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 12th Jan 2010 - Footings etc. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 13th Jan 2010 - Pad Down Like ⋅ 10 comments ⋅ Pin to Ideaboard ⋅ 28th Jan 2010 - Bricks! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 4th-7th Feb 2010 - More Bricks (Brickwork Near Completion) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 11th Feb 2010 - Roofs Going Up! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building with RedInk Custom 5000 Expected Finish Date - May 2010 Re: Custom 5000, RedInk Homes in Mandurah (1st Home) *Photos* 2Feb 12, 2010 12:31 pm Another Redinker! Welcome Ry34 Good going squeezing in for the first home buyers grant, and Redink has done such a good job for their first home buyer's market with the Evo/Custom/Benchmark series. The staff will take care of you too So what kind of colours did you choose? Re: Custom 5000, RedInk Homes in Mandurah (1st Home) *Photos* 3Feb 12, 2010 12:38 pm Great looking plan Ry34!! So big and spacious, you'll be swimming around the place Your build seems to be going really well so far viewtopic.php?f=31&t=22766 - my build thread! Time waits for no man. Unless that man is Chuck Norris. Re: Custom 5000, RedInk Homes in Mandurah (1st Home) *Photos* 4Feb 14, 2010 11:13 am Welcome Ry34 I am also building the custom 5000 in Mandurah but I havent even got a slab yet. Your theatre design has got me second guessing mine now . I would really like to see it in the flesh if you were willing to pm me your street name. The major change I made to my 5000 was relocate the wc and bath to the activity, spin bed 2 90 degrees, delete hall wall and bingo, a 4x4m closed of activity was born . Much better than the standard sise activity, but I really have stuffed the zoning up which may come and bite me in the *** come live in time. I upgraded all clay internals to accoustic maxibricks ($1014) to try and counteract, but only time will tell if thats enough. Cheers Re: Custom 5000, RedInk Homes in Mandurah (1st Home) *Photos* 5Feb 14, 2010 11:30 am Welcome, we're building the Benchmark with red!nk , we're also in Mandurah! I have a friend who said her brother also Ryan was building this house in Mandurah as well, you wouldn't have a sister would you? Re: Custom 5000, RedInk Homes in Mandurah (1st Home) *Photos* 6Feb 15, 2010 3:20 pm Ventura Victory??? Your theatre design has got me second guessing mine now . A couple of reasons behind my theatre design... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Moved the doors from (1) to (2) because where the doors were originally placed meant you had to put your tv/couch against wall (2) and (3) (cannot have a couch in front of the window (4)). With the new design, my couches can go along wall (3), TV & cabinet can sit nicely in the middle of wall (1) or in my case I'll hang a projector from the ceiling above the couches (3) and project an image onto the wall (1) I can put speakers and/or shelves in the extra nooks either side of the screen. Building with RedInk Custom 5000 Expected Finish Date - May 2010 Re: Custom 5000, RedInk Homes in Mandurah (1st Home) *Photos* 7Feb 16, 2010 3:52 pm Ry34 Ventura Victory??? Your theatre design has got me second guessing mine now . With the new design, my couches can go along wall (3), TV & cabinet can sit nicely in the middle of wall (1) or in my case I'll hang a projector from the ceiling above the couches (3) and project an image onto the wall (1) I can put speakers and/or shelves in the extra nooks either side of the screen. Yep, it certainly looks the part. I also think the nooks created in the hallway are really going to up-spec your entry hall. Unfortunately, its not an option for me as my dining room table is going to be on the other side of where your double entry doors are. My doors are only 720 each and are located on the corner of (1) and (4). I am hoping that I wont loose too much of wall (1)s usable length as the 1st opening door is the one closest to (4) and I plan to put a speaker directly behind the permanently closed second door. I have the option of couches on wall 4 as I have changed the 2 awnings to 1 double sliding window, high enough to fit a couch underneath. I want rollershutters which are not possible with awnings. Oh, If you dont already know, the sparkies are doing your prelay today, and your colourbond has arrived. Have you calculated if a HDMI cable will fit down your 32mm wallplates ? Whats your plans for your "linen"? With all those wallplates/powerpoints, it looks like its going to be a server room ! Lastly, did they use a concrete pump for your slab pour ? Its a $1000 charge I really want to avoid, but my salesman says they are being used very regularly, even if they have good access. Thanks for allowing me to take a peek Pete Re: Custom 5000, RedInk Homes in Mandurah (1st Home) *Photos* 8Feb 16, 2010 4:58 pm Ventura Victory??? Oh, If you dont already know, the sparkies are doing your prelay today, and your colourbond has arrived. Have you calculated if a HDMI cable will fit down your 32mm wallplates ? Whats your plans for your "linen"? With all those wallplates/powerpoints, it looks like its going to be a server room ! Lastly, did they use a concrete pump for your slab pour ? Its a $1000 charge I really want to avoid, but my salesman says they are being used very regularly, even if they have good access. Thanks for allowing me to take a peek Pete Had a quick look at the house yesterday, they were removing bricks from the site. I'll swing by and take a look this afternoon on my way home I hope an HDMI cable will fit, if not I'll have to make it fit... My "linen" is really just a wiring closet, telephone/tv aerial point/network/etc. They used a concrete pump (even though the block was completely flat and only had one neighbouring house at the time), seems as thought they make you pay the $1000 to make the concreters job easier/quicker Building with RedInk Custom 5000 Expected Finish Date - May 2010 Re: Custom 5000, RedInk Homes in Mandurah (1st Home) *Photos* 9Feb 16, 2010 7:41 pm Vundaful! Another Redinker! Welcome Ry34 Good going squeezing in for the first home buyers grant, and Redink has done such a good job for their first home buyer's market with the Evo/Custom/Benchmark series. The staff will take care of you too So what kind of colours did you choose? Colorbond Roof: Jasper Gutters & Downpipes: Dune Garage Door: Jasper Kitchen Top: Roman Marble (Flint Finish) - Laminex* Kitchen Bottom: Streetlight (Velour Finish) - Formica Bathroom Top: Concrete Stone - Formica Bathroom Bottom: Fini Chocolate - Formica Kitchen top was originally dark formica but I was advised it wasn't available at the time, so they upgraded my tops to laminex for no extra cost Building with RedInk Custom 5000 Expected Finish Date - May 2010 Re: Custom 5000, RedInk Homes in Mandurah (1st Home) *Photos* 10Feb 16, 2010 7:48 pm Lovely, that Jasper colour is a really popular roof colour in my estate. Score on the free upgrade! Re: Custom 5000, RedInk Homes in Mandurah (1st Home) *Photos* 11Feb 18, 2010 10:10 am 16th Feb 2010 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 18th Feb 2010 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Roof is up! Building with RedInk Custom 5000 Expected Finish Date - May 2010 Re: Custom 5000, RedInk Homes in Mandurah (1st Home) *Photos 13Mar 08, 2010 11:29 am Haven't posted for a while, here are a few updates: House is plastered, ceilings and cornicing finished. Windows/Doors should be in this week I had a look at the place yesterday and head running water, when i looked a bit closer, it must have been coming from the laundry. The first thing I did was turn the water off at the mains. Here are a couple of photos of what I found... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The wall was so damp and the plaster was going sludgy/crumbling at the edges.. I have told the supervisor about this and emailed him the photos. I also saw this when I walked behind the house... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Is this just plain carelessness? Do you think this will leave me with stained bricks? Building with RedInk Custom 5000 Expected Finish Date - May 2010 Re: Custom 5000, RedInk Homes in Mandurah (1st Home) *Photos 14Mar 08, 2010 8:25 pm I really love what you did with the theatre, wishing I had done something like that with mine now!!! Good to see another Custom500-er Built with RedInk Custom 5000 Key Handover 15/12/2009 Re: Custom 5000, RedInk Homes in Mandurah (1st Home) *Photos 15Mar 09, 2010 11:33 am I wouldn't worry too much about the brickwork, the brick cleaners will get that off. Its a bummer about the leak, but try and look on the bright side, at least you know your weep holes are not blocked. Now the plaster is on, it really shows the size of the house. The family room is huge. I saw ref_kt's family room through the window and that was huge, but actually seeing it inside really brings it into perspective. Your theater "RECS" really set the theatre off, and how it up-specs your entry is such a bonus. The 4 wall plates for your speaker cables has really added that professional touch. I have measured all 4 of my HDMI cables and the widest is 24mm, so you will have no problems getting them up the 32mm conduit. Where do you intend mounting your projector ? I am going to bore a hole in the wall between the theatre and the linen wall and mount it on a shelf on the linen wall. the ultimate hush box. Re: Custom 5000, RedInk Homes in Mandurah (1st Home) *Photos 16Mar 12, 2010 10:45 am Windows are in, doors are inside ready to be hung. Ventura Victory??? Your theater "RECS" really set the theatre off, and how it up-specs your entry is such a bonus. The 4 wall plates for your speaker cables has really added that professional touch. I have measured all 4 of my HDMI cables and the widest is 24mm, so you will have no problems getting them up the 32mm conduit. Where do you intend mounting your projector ? I am going to bore a hole in the wall between the theatre and the linen wall and mount it on a shelf on the linen wall. the ultimate hush box. Thanks! I was thinking about adding a couple of small halogen lights in each of the recesses in the hallway later on which should liven up the hallway at night The plan was to ceiling mount the projector as high and far back as possible (of course this depends on the projectors throw distance). Building with RedInk Custom 5000 Expected Finish Date - May 2010 Re: Custom 5000, RedInk Homes in Mandurah (1st Home) *Photos 17Mar 12, 2010 10:55 am Building with RedInk Custom 5000 Expected Finish Date - May 2010 Re: Custom 5000, RedInk Homes in Mandurah (1st Home) *Photos 18Apr 13, 2010 12:19 pm 12th April 2010 - Garage Door Installed Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ It's been a while between updates, but its almost finished. Kitchen is in apart from the hotplates. Ensuite is waiting on shower screens. Bathroom waiting on tub + shower screens. All lights and power outlets have been installed. Driveway is going in next and painters sometime after that. Looking for timber flooring and carpets now (since I chose to do this myself), can anyone recommend a place around Perth or Mandurah to get some prices from? Building with RedInk Custom 5000 Expected Finish Date - May 2010 Re: Custom 5000, RedInk Homes in Mandurah (1st Home) *Photos 19Apr 13, 2010 12:43 pm you wont be alone for long! good job, fab house..well done you!! Re: Custom 5000, RedInk Homes in Mandurah (1st Home) *Photos 20Apr 23, 2010 12:51 pm Hey nice changes you made, it looks good. i also had the same problem in the laundry with mine but it was quickly fixed. And also now we have just moved in i have noticed a similar problem with the rear tap leaking, so im trying to get the builder to fix it now Regards Jeremy Building in southern river Perth.. Hi there, We’ve recently had plans approved to add a 1st storey addition to our existing house for a growing family in Sydney. With the current cost of building… 0 4294 Hi, can anyone recommend a custom home builder who can build in north east area? Looking to build a custom 4-br energy-efficient home with a max budget of 750k. If they… 0 22812 |
