Browse Forums Building A New House 1 Feb 10, 2010 9:13 pm We had a call today in regards to our ducted air con. We were told by the air con company, that the motor that comes with the house is not big enough to run the 6 zones. To upgrade to the next size would be $1600. Rang coral now waiting on a response....Not happy Our land gets cut tomorrow Cherie Re: Air con not big enough?? 2Feb 10, 2010 10:26 pm Is that the one provided by Coral? What size unit do they think you need? Nic. Built the Coral Homes Hamilton 252 - moved in 20/10/2010 and loving it!! https://forum.homeone.com.au/viewtopic.php?t=27215 Re: Air con not big enough?? 4Feb 12, 2010 11:19 am Hi Coral were giving us a 17kw, air con guy said you can not run all 6 zones at once. Clements said for a 18kw it was $1600.00 up grade, but i then rang coral and asked, they said the house was too long???? Coral got a quote from same company for a 20kw for $1375 so we are going to go with that as it will be more energy efficient Cherie As per title, unsure if my land doesn’t have enough fill. The house on the left seems to have higher elevation. Not sure if the empty lot in between has just been… 0 534 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5929 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 |
