Browse Forums Building A New House Re: New Home Inspections, and any other inspectors in Vic? 27Nov 19, 2012 6:25 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: New Home Inspections, and any other inspectors in Vic? 32Apr 29, 2013 4:59 am 3in1 Supadiverta. Best Practice Rainwater Harvesting using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: New Home Inspections, and any other inspectors in Vic? 35May 20, 2020 10:44 pm ![]() Hey all, for those checking this thread still in 2020, and for those looking for an IBI for their new builds - for Melbourne the below are pretty much the recommended Independent Building Inspectors (IBI) if using a volume builder (eg: M , B , PD etc) or are there others you would recommend? Peter Limburg (Final Inspect , 0408 132 152) David White (Building Watchdog Inspections , 0418 322 925) Darren Love (Darbecca , 03 5367 2111) Branko Mladichek (A Plus Inspections [T/A Building Expert] , 0409 029 680) Mike Heathcote (Building Masters Inspections , 1300 033 332) David Seville (Seville Building Quality Inspections , 0488 993 332) Kevin McDonald (New Home Inspections , 03 9708 2500) Sam Mamone (Inspect Direct , 0403 207 146) Michael White (Complete Property Inspections , 0411 487 300) Paul (Urban Property Inspections , 1300 071 283) Houspect (03 9808 4000) Awesome work thank you TeslaCyberTruck Re: New Home Inspections, and any other inspectors in Vic? 36May 21, 2020 2:50 pm I would really question the value of a full circa $2,000 'package' of building consultants' progress stage inspections for savvy new home buyers. I believe a typical approx. $400 pre-linings inspection report is critical. A professional inspector should identify and document any significant defects before they are covered up with plaster and hidden. Accompany the inspector to ensure everything is checked and you understand the issues, how they are fixed, and relative importance. You can visit with the SS later to confirm the defects have been rectified before plastering starts. If you don't check yourself you can assume they have not been rectified. Your SS won't check: "It's all good!" The value of the other stage inspections' in the circa $2,000 'package' deal is questionable, and very limited. The remaining $1,600 here is better spent elsewhere, particularly when you can easily see and check exposed surfaces carefully and slowly yourself. Private building consultants have no authority over the builder. Many builders have very little interest in, or respect for building consultants' reports, and these are not formatted for building tribunal cases therefore you might as well just do the other basic inspections yourself. For serious defects that he builder refuses to fix you need a beefier report that has legal credibility. You will need to pay extra for an expert witness report. Better to learn a bit about the relevant standards yourself, use a checklist, spend about $500 on some basic tools and protective gear at Bunnings that you can use to inspect yourself on your weekly 2 hour site visits, with the permission and / or assistance of your site supervisor. Take photos and document everything in the professional formats used in inspectors sample reports found online. The are good examples of professional defect report formats to be found on inspection company's websites. Built in 2011, had Termimesh installed as part of the build and still get annual inspections done. That said I'm pretty sure if we did have an issue Termimesh would… 2 815 ![]() Thanks, yes I saw this one dated 2013. Thanks for having a look for me. Wondering if anyone else has used this company before? Cheers. 2 266 I am using https://southwestpropertyinspections.com.au/ for all inspections - Pre Slab, brock, frame, pre lining , PCI etc. I would not trust a builders independent at… 5 1726 ![]() |
