Hi all,
This is a photo of our housebuild. It is progressing very speedily, which is great.
However, today I noticed something, and was wondering if it is noticeable. I hope it isn't !!
Answers appreciated.
Browse Forums Building A New House Re: Spot the problem 8Aug 04, 2007 5:40 pm damn!!!!! correct!!!
Thanks Damo...is it that obvious? What do you think I can do about this? I'm sure the bulders are covered by some kind of clause about brick variations between batches. Would you all say that this is a major flaw? Re: Spot the problem 10Aug 04, 2007 5:44 pm Its the whole side of the house.
The 1st storey is a different shared to the 2nd storey Has anyone else had this problem? I can understand how batches can be different...but it would have been nice if they've ordered all of the bricks in one go. Re: Spot the problem 12Aug 04, 2007 5:59 pm at least they remembered your eaves and didn't leave a big black box on your roof...
the front bricks look more uniform and they are under full light so it could just be an optical illusion... ie. could it be variation in mortar style casting more shadow on the lower floor? Re: Spot the problem 13Aug 04, 2007 6:15 pm no optical illusion I'm afraid.
They completed the bricks on the ground floor a month ago..and then ordered the bricks for upstairs. Oh well..and to think my parents were going to build with them. They will reconsider now, unless we get some compensation. Re: Spot the problem 14Aug 04, 2007 7:47 pm Firstly Jazz i would just tell everyone that's how you wanted it. Mention something kind of intelligent sounding that refers to light and sizing, eco sustainability or whatever else prevents people from asking further questions. Then you could always let the builders leave their mess behind because i was too busy looking at that to notice the brickwork! Re: Spot the problem 15Aug 04, 2007 8:29 pm The house across the street from us have the same colour scheme and bricks that are very similar. But theirs is a lot worse than yours!
Anyway, I thought they tint the bricks so that it matches? It's kind of like my issue with our tiling - if you can see it with the naked eye then it's something that definitely needs to be fixed. What does your builder and supervisor say? [sneakersss] Re: Spot the problem 16Aug 04, 2007 8:36 pm My understanding was that brickies were meant to mix the bricks from different pallets to avoid this problem. Although from what you have said it seems they didn't have enough bricks when they started.....
Another forum member had similar problem when some brickwork was repaired and is having the lighter brickwork tinted/dyed...the link is here https://forum.homeone.com.au/viewtopic.p ... highlight= Re: Spot the problem 17Aug 04, 2007 10:43 pm The problem with the brick colour was immediately obvious to me. I think it needs to be fixed and there are tinting methods available (and mentioned in this forum) that may be acceptable. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Spot the problem 19Aug 05, 2007 12:24 am I have seen one of our builder's customer having the same problem as you: bricks delivered later are from different batch and there's a quite obvious colour differences between the two.
But he is much luckier than you, because they check their site almost everyday and was able to pick it up very early in the stage. The brick layer only used some of the bricks and our friend demand it to be stopped right away. From builder's point of view, they insist it's not their problem as they ordered the same brick and they refused to re-order. Our friend just refuse to accept that, after lots of phone calls and arguments, with the whole construction delayed for more than a month, the builder finally give up, remove those bricks in the wrong colour and re-order new ones... I think in your situation it's a bit too late to ask they to knock down those bricks and re-do the whole wall. You can try and fight for some compensation or rendering... Re: Spot the problem 20Aug 05, 2007 12:54 am Hopefully by the time that nextdoor build their 2 storey house, it will be not that noticable. 6 2994 2 3747 I don’t think so as the floor area over 300 square meters then it is class 3…. 12 15888 |
