Browse Forums Building A New House Re: Site Cost 2Jan 27, 2010 4:02 pm Hi Yellow search for the thread - What Were Your Site costs? - A Ready Reckoner Re: Site Cost 3Jan 27, 2010 4:06 pm Hi Yellow, Your question is a little ambiguous and so will be my answer Site costs vary significantly based on engineering design of your footings that are required to be able to build a particular house on a particular block plus any additional costs due to access and/or increased costs in excavation cut and fill that may be required. The design is made based on the details of a soil survey which the builder has a contractor undertake on your block to ascertain what sort of class soil your block is in the building zone. So depending on your soil test and the size of your fall which then effects how much if any cut/fill and any applicable retaining walls is required to be undertaker. So yeah the short answer is "how long is a piece of string?". Once you provide details for your site before signing the contract the builders are required to estimate the costs in order to produce a fixed price contract but until you sign up and hand over your downpayment no builder will spend the money on your behalf to have a soil test undertaken. If you really want to know the other option if you have already setteled your land would be to hire a survery/geology company to perform the soil test for you to give you some idea, but thats likely to cost you similar money to paying the downpayment to PD. Also if you use the search button there is an old thread lurking where a range of people listed what their site costs had been for their individual situation, it might give you an indication. Our Build - Places Fairhaven 23+ - https://forum.homeone.com.au/viewtopic.php?f=31&t=28045 Our Landscaping - Belial's Backyard - https://forum.homeone.com.au/viewtopic.php?f=19&t=45375 Re: Site Cost 5Jan 27, 2010 4:26 pm We are currently building with PD and they estimated what you have been told also. They usually have an idea if they have built before in the same estate. We were lucky that the site costs came in well under what was estimated But the figure estimated earlier helped in the budget / finance area. We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37155 Thanks for the insight! My plot is a new development so hopefully I won't have too much problem during build as everyone should be roughly building together. I also… 2 3380 Approvals are covered in the cost we are paying to the pool company. The only thing stated in our home build contract for the additional cost is engineering support. … 3 7134 |
