Browse Forums Building A New House 1 Jan 27, 2010 10:42 am Hi all, I have seen a few posts where people don't opt for the full render (and instead go for the Moroka finish) simply because of the cost blow out. Can any give me a ball park idea of the difference? I am not intending ot render an entire new house but maybe just half. Any rough comparisons between total cost of the 2 would be appreciated so I can get an idea what to expect! Re: Full Render - How much extra $$ are we talking about? 2Jan 27, 2010 11:34 am We have a 25 square house. It cost us $2200 to have the front rendered. It was going to cost us $12k to have the entire house rendered. Lara and Joshua http://pdheywood25.blogspot.com/ viewtopic.php?f=31&t=31186 16.03.10 Scrape 29.03.10 Slab 08.04.10 Frame 11.05.10 Lock Up 03.06.10 Fixing 24.08.10 Handover Re: Full Render - How much extra $$ are we talking about? 3Jan 27, 2010 11:43 am If you like the rendered look, see if you can find a builder who will work with hebel powerpanel or the likes... I think that the cost turns out to be almost comparable with brick because the installation times are so much lower, and that would get you a fully rendered house. Ours is using hebel and it looks amazing. No idea what the brick cost equivalent may have been as our builders use hebel by default... Re: Full Render - How much extra $$ are we talking about? 4Jan 27, 2010 12:06 pm If you worked out the square metres of render you are looking at, then allowed render around the $40-45 per square metre, you would be pretty close to what it will cost you extra. Blog is now up - http://www.jbdave.blogspot.com/ Re: Full Render - How much extra $$ are we talking about? 5Jan 27, 2010 6:33 pm jbdave If you worked out the square metres of render you are looking at, then allowed render around the $40-45 per square metre, you would be pretty close to what it will cost you extra. From this cost you can deduct the reduced brickwork cost. You'll be going from face brick to common brick, which are both cheaper to buy and cheaper to lay. Demolition August 2009, Construction Started September 2009, Completed December 2010 Elvis has left the building... The site supervisor quit after 2 month on the project. I guess he was just instructed to bark at people, but didn't like when he was… 26 21031 Hi Kristy Around $1.7-1.8m or around $4,600/sqm. if you PM me your email I will send you a break up in a spreadsheet so you can get an understanding of the costs for… 1 12489 |
