Browse Forums Building A New House Re: Site works - and Soil Terminology 2Jan 25, 2010 5:30 pm All i can tell you is M is a good one to have (medium reactive). No major works required for a slab. Also i think H is another good one to have where as P (Problem) is a bad one, major works in the footing and reinforcments, piers in the brick work etc. Usually meany its basically land fill or all top soil. Re: Site works - and Soil Terminology 3Jan 25, 2010 5:36 pm You should have a glossary on your soil test to explain the site classifications. 'M' is a pretty average site. Basic Description is moderately reactive site, have only slight potential for ground movement through moisture change. A lot of people would be very happy to have a 'M' classification, we had 'P-M' due to some fill on the site so we had extra costs for piering. If you are unsure of the report call the soil tester and they will explain it too you in more detail. Cheer Lou http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys Re: Site works - and Soil Terminology 5Jan 26, 2010 2:53 am The forum search function is your friend... This thread should interest you: viewtopic.php?f=31&t=9017 Built with Sw1tch H0mes >Build thread< House status 15/12: Gates and A/C finally installed! Sep 09 Bought block, Dec 09 Engaged builder, Jul '11 Moved in We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37756 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10358 MBA and HIA both have sub contract agreements, check them out 2 7416 |
