Browse Forums Building A New House 1 Jan 19, 2010 7:25 pm Hi Guys I have recently joined this site and I am hoping someone can help me with my query. I purchased an old house on a relatively large block (620m2), which I am looking to knock-down and rebuild. I want to build the biggest possible double story house that I possibly can and have a minimun backyard. However, blacktown council's website only states the regulations for floor ratio for single storey dwelling. Can someone please tell me: 1. what is the biggest double story dwelling that i can build on this block; and 2. can i subsequently/simultaneouly build a granny flat at the back of this new house, and if so, is the size of the granny flat included in the total allocable building 'quota' (i.e. will the area of the granny flat reduce my maxium in 1?) or is it spearate. Many thanks guys. Re: Blacktown Council (NSW) Regulations 2Jan 19, 2010 8:09 pm Hi, There is more info in the NSW Housing code http://www.planning.nsw.gov.au/LinkClick.aspx?fileticket=vRfs3aH1tLg%3d&tabid=103. Once you get a good idea exactly what you want to build, you can have a free pre submission meeting with Blacktown council to discuss details. Good Luck with your build. Min Building at The Ponds Land reg 3/12/09, Land settled 18/12/09 Approved by Design Panel 16/11/09, Submitted to council 24/11/09, Approved by Council 21/1/10 Site Start 21/5/10 http://andyminpondsbuild.blogspot.com/ https://forum.homeone.com.au/viewtopic.php?f=31&t=19800 Re: Blacktown Council (NSW) Regulations 3Jan 19, 2010 8:19 pm We're building in Blacktown Council as well. While I don't have an answer for you directly, I can say this: We've called Blacktown numerous times about different building related questions and they are extremely responsive and helpful. I have been very surprised with the feedback and level of support Council has provided us - to the point where they'd return calls if they couldn't answer or correspond via email. In short, I'd just call Council and ask! Stefan Building the M3tr!con Liberty 42 at Stonecutters Ridge. The New Build Blog - "Life, In Progress." Stonecutters Ridge Community Website | My photos Re: Blacktown Council (NSW) Regulations 4Jan 19, 2010 8:21 pm Have you had a read of the councils development control plan? This should answer most of your questions. http://www.blacktown.nsw.gov.au/shadomx/apps/fms/fmsdownload.cfm?file_uuid=C1BD14A9-F26E-BD6F-C5EA-BCD769597035&siteName=blacktown Thats the link to part c development in residential zones. Max building height is 9m above the lowest adjacent natural ground level. Andy Re: Blacktown Council (NSW) Regulations 5Jan 19, 2010 8:48 pm thanks guys. andy - this was the document I was after. I have viewied the NSW planning regulations, and hoped that the council may allow a larger dwelling to be built. Cheers Re: Blacktown Council (NSW) Regulations 6Aug 16, 2015 11:34 pm May be this topic is a little bit outdated, but I think this is the most appropriate place to ask. One sales person in Kellyville Homeworld said that it is possible to build a two-storey house with 950mm (0.95m) side gaps to neighbours even if the first (upper) floor will also be with 0.95m gap. He said this is some new requirements. Is it true? Thank you. Also I would like to share what I heard from different "builders" (actually different sales people) in common about blacktown city council requirements in Alex Ave and Rivestone Precincts: - back should be 4 meters for the ground floor and - the first floor 6 meters - garage 5.5m - front setback is 4.5m, but (and it may be important to many people) if the lot is facing nature reserve, retreat or park, then front setback may be just 3.5m. - if your lot is small and less of equal 375 sq.m then you can build up to 60% on the ground floor and up to 40% on the first floor - if your lot is 375+ sq.m then upper level could take up to 35% (it could be a nice math trap for many: if your lot is 374.9 you upper floor could be up to 149.96, but if your lot is little bit over 375, say 375.1 then your upper floor could be at most 131.285, lovely isn't it? Actually it means that buying a bigger lot from 375.1 to 428.5 does NOT increase your potential of building on upper floor, vice verse it DECREASES - single storey 0.95 to you neighbours on sides... Building Casaview Denison 30 https://fortdenison.wordpress.com/about Re: Blacktown Council (NSW) Regulations 7Aug 18, 2015 8:18 pm Also (may be somebody knows) what set back if any is allowed for balcony if the front of the house? Building Casaview Denison 30 https://fortdenison.wordpress.com/about Re: Blacktown Council (NSW) Regulations 8Aug 20, 2015 6:51 pm have found this: http://growthcentres.planning.nsw.gov.a ... 1_to_6.pdf Building Casaview Denison 30 https://fortdenison.wordpress.com/about This was on google. Development controls 2.3.1 Front setback D1 New buildings within residential areas shall adhere to a front building line, which is 5.5-6m to the… 1 3677 Thanks again for this information. If you do hear anything different, would be great to know 4 8256 If you don't want to annoy the neighbours then simply get yourself some good head phones. For me the sound is much better using headphones. The NCC (National Construction… 1 26171 |
