Browse Forums Building A New House 1 Jan 16, 2010 6:52 pm Hi Work on the Besser Block retaining wall continues in earnest. 2-3 rows done and dropped in a dose of 10mm gravel and 80mm Ag Pipe (with Sock) and then 10mm gravel on top The pipe comes in 20m lengths so 20m across the back and around the corner to the side wall Need to jopin the 20m roll I'll run down the side. Is there a standard join to use? Thanks Re: Joining Ag Pipe 2Jan 19, 2010 8:58 am Hi Wombat Yep you can buy joiners - there are a bunch of different types, 2, 3 and 4 port and then there are the Y type as well. Have a look at this link. Bunnings sell ag pipe as well so they will more than likely sell a range of joiners also. http://www.materialsintheraw.com.au/lan ... oiner.html yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7326 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4872 I think you are getting different numbers because they all just based them on "other jobs" even though each job is unique. Often, with builders, unless you're speaking to… 3 3241 |
