Browse Forums Building A New House Re: 4 Bricks over window - 3 Bricks over S/D...would this irk u? 12Jan 16, 2010 11:21 am Casa2 The heads of your windows and matching doors should all be at the same height. They have not been installed as such. Whoever placed the windows did not place them correctly. Would be good to see a wider photo that shows as many windows a possible as well as the base of the windows. At risk of being pedantic... it could be a window supply problem. The timber frame could be right, the brickie shouldn't make the decision on how to finish to suit the gap as maybe it shouldn't be there. The windows maybe should have been 40mm taller. There's not enough information. You need the plans & elevations and the window schedule. It is wrong and it needs investigating... I would complain. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 You can wash over existing pavers with 10% solution of water and hydrochloric acid, then wash off. The acid will provide for required bond key with new concrete. 1 36925 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5222 |
