Browse Forums Building A New House 1 Jan 12, 2010 8:12 pm Hi Everyone, I have read so many different threads on this forum in regards to Henley homes and peoples positives and negatives. I have also read the product reviews on a different site which are really scary. We love the Henley Lexington and the Voyager plans and are seriously considering building this. I was hoping people that have built with them can give me an answer as to if I should go ahead and the main things to look out for. The other thing I would really like some info on is how Henley homes are shaping up for quality after 3 -4 years after build. This sounded like a major concern on the product review site. Issues started with quality after a couple of years was a common post. Any feedback would be awesome. Thanks for your help guys............. Re: Advice on building with Henley 2Jan 12, 2010 8:22 pm Product review sites will tell you horror stories for ALL builders. Check out the blog thread viewtopic.php?f=31&t=1522&start=0 for all the people building/built with Henley. I love the plan on both the houses you've narrowed it down to. Good luck with it all Hi, If you give a set of criteria as to what means 'good' to you, it'll give others prompts to respond. We considered Henley early on but there were two factors that… 1 10526 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18092 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 |
