Browse Forums Building A New House 1 Jul 27, 2007 7:12 pm hi everybody,
we have had our practical completion inspection today and quite disappointed. one of the things that bothers me most is that the "cupboard doors" are chipped a "little bit" at the bottom corner. The reason my building supervisor gave is it happens all the time when as the doors are painted before fixing and it might happen while transporting or fixing them. I am not impressed with his reason and not sure if i am being too fussy but isn't it supposed to be undamaged and brand new if it's a new house. Please advice what I can do abt this...Thankyou sooo much!! Re: final house inspection 2Jul 27, 2007 7:14 pm hi! I don't think that chipped doors are acceptable at all!
It's the builder's responsibility to provide a product in new condition. If he cracks a tile while laying in the kitchen - he doesn't lay the pieces of cracked tile - he should put down a new tile. Same with kitchen cupboards. Or scratches on stoves or ovens. And don't allow them to just "touch it up" with paint - it will look cheap and nasty - ask them to replace the door. Definitely don't pay them their final instalment either Re: final house inspection 3Jul 27, 2007 7:59 pm Firstly Thanks for your reply 'stonecutter1309'.
will try asking them tomorrow as we had already signed the inspection papers today. Not sure if its possible after signing the docs. Re: final house inspection 4Jul 27, 2007 8:20 pm Thats sounds *******!
Definatley not acceptable.... Who was your builder? Re: final house inspection 6Jul 27, 2007 8:30 pm we are with porter davis and the chipping off is very little but doesnt look professional just with this thing..rest is all good Re: final house inspection 7Jul 27, 2007 8:33 pm If it makes you unhappy, have it fixed.
You will always remember it otherwise. PD are usually pretty good with this sort of thing I believe. Let us know the outcome. Re: final house inspection 9Jul 27, 2007 9:31 pm one more question guys:
we already signed the practical inspection papers with few conditions like: pach-up paint work and fix the skirting. Just wondering if we are still eligible to ask for the things which we didn't include in the inspection checklist. Re: final house inspection 10Jul 27, 2007 10:04 pm When did you pick it up?
If it was during the inspection, mention it to your CSR and it should be fine. Send an email and follow it up with a call on Monday morning first thing to be sure though Re: final house inspection 11Jul 27, 2007 10:06 pm I fully agree with stonecutter. You're paying for a new house, not a new house with chips and scratches.
Your builder's excuse is, pardon the french, a crock of #$#%. They are basically admitting liability to transit or handling damage as a result of poor packaging or fixing practices. I'm tipping the cause to be on site handling damage, as after the doors were manufactured and sprayed, they most likey would have have been bubble wrapped prior to despatch. If this didn't happen, you'd probably see rub marks on the faces of your doors, from where they were stacked on top of or against each other. I assume that the chips occurred during fixing, after the doors were unwrapped on site. The cup hinges have to be screwed in then the doors are fitted off and adjusted for up, down and in/out positioning. I'd guess that they were probably unwrapped and sat on edge leaning up against a wall, or just carelessly handled so the edges have copped a hiding during fitting. It all depends how much you're prepared to compromise (especially if you're facing time or money pressures). They can either replace the doors, touch up the chips, or leave them as - is. Me, I'd be going for replacement, as a touch up will look cacky - there'll still be chips, they'll just be covered with a single layer of brushed on paint, as opposed to the surrounding area which will be a sprayed on layer of primer plus one or two layers of paint. Well, that's my rant over and done with. Poor workmanship and lack of pride in one's work really gets my back up. Cheers, Justin. Re: final house inspection 12Jul 27, 2007 10:23 pm Justin I fully agree with stonecutter. You're paying for a new house, not a new house with chips and scratches. Your builder's excuse is, pardon the french, a crock of #$#%. They are basically admitting liability to transit or handling damage as a result of poor packaging or fixing practices. I'm tipping the cause to be on site handling damage, as after the doors were manufactured and sprayed, they most likey would have have been bubble wrapped prior to despatch. If this didn't happen, you'd probably see rub marks on the faces of your doors, from where they were stacked on top of or against each other. I assume that the chips occurred during fixing, after the doors were unwrapped on site. The cup hinges have to be screwed in then the doors are fitted off and adjusted for up, down and in/out positioning. I'd guess that they were probably unwrapped and sat on edge leaning up against a wall, or just carelessly handled so the edges have copped a hiding during fitting. It all depends how much you're prepared to compromise (especially if you're facing time or money pressures). They can either replace the doors, touch up the chips, or leave them as - is. Me, I'd be going for replacement, as a touch up will look cacky - there'll still be chips, they'll just be covered with a single layer of brushed on paint, as opposed to the surrounding area which will be a sprayed on layer of primer plus one or two layers of paint. Well, that's my rant over and done with. Poor workmanship and lack of pride in one's work really gets my back up. Cheers, Justin. Remind me never to "Near enough is good enough" with you around!! Likely to go troppo! Re: final house inspection 13Jul 27, 2007 10:31 pm Ultimately it doesn't matter how they were damaged. Fix it. Simple as that.
I am early into my building process, yet I can already forsee some minor issues, which I am sure I will make them fix. For example, although most of the windows still has plastic wrapping over them which is good, sliding doors does not, as well as one or two windows. Now that the brickies just finished their job, the sliding doors have little bits of mortar inside the rail as well as all over the glass. I know it's going to be washed but I've told the supervisor that if the door doesn't feel and look 100% brand new, I will demand a replacement. Has to close and open as new. I am sure there will be another 100 minor items between now and handover, but as long as it's all fixed by the end of it, I'll be happy. Currently Building in Bayside (Brighton East) Re: final house inspection 14Jul 28, 2007 4:46 pm Thx guys, I am just overwhelmed with the support in this website..Now, I have got some guts to ask my builders..I am not going to leave it as I am not able to compromise myself..
This is my first home and dream coming true. I don't want to feel it as a second hand quality after i move in. Each and everybit of the house should be to my satisfaction and that's what I am paying for I guess. I wrote a letter to PD today explaining the damage. Will see what they are gonna say and keep you all posted.. bye till then.. Re: final house inspection 15Jul 29, 2007 10:42 am If it's not too late, is it possible to get a builder inspector to have a look? It might cost a few houndred dollars (NSW about $350-$400), with their professional knowledge & advice, they might pick up something you missed. Re: final house inspection 17Jul 31, 2007 4:37 pm Everybody is spot on!! Get it fixed. We had a couple of chips in the bottom of the cupboard doors as well and the supervisor didn't flinch at getting it fixed. 2 days later when we came back it was good as new. No idea how they fixed it and I never asked but we were happy that they fixed it without telling us we were being pedantic!!!
Amber http://www.ourdreamhouse.blogspot.com i would suggest nothing is unreasonable for PCI. we did all sorts, including checking the hot water, checking all the GPO's had power, testing that the showers were… 9 98680 The significant date is when receive final payment invoice Check that section of contract Bit of fluff by builders prior to that 1 15946 Hi, I am approaching end of the build. My final invoice will be given to me soon to pay. Some context before I ask my question. 1. My builder wont do the landscaping or… 0 3865 |
