Fencing leeway - urgent help!
What's the margin of error or whatever you want to call it for the fence on a boundary in Victoria? Is it 100mm?? 150mm?
So say for example my neighbour has a distance from his slab to the boundary of 1800mm (or 1820mm) I have 1200mm from slab to boundary and now with the fencing rails up mine is more like 1240mm and his is 1740mm and the width of the fence is 50mm is that too far off course?
My neighbours garage is on the boundary and we are only fencing to the rear of the garage and they have fenced to that and it is the same measurement all the way down!
I don't feel so worried now, but still would like to know to what the acceptable allowance is
So its somehwere between 40-60mm off? I dont see that as being a problem
Thanks Bam, I don't see it being a problem but my neighbours might!
Seems to be slightly off to your advantage. Would your neighbour pick it up?
If he brings his tape measure, he is an engineer but as I just posted I can see what the fencers have done so not as worried
Stonnington's website says that "there is no statutory definition as to the correct position a fence should be placed with relation to a title alignment" (http://www.stonnington.vic.gov.au/www/h ... undary.asp) if you follow the link the report it refers to says that the exact positioning of a fence i.e. is it the paling, the "median" point, is a bit vague.
You could mention it to your neighbour....engineers aren't that scary...
I read somewhere...on a council website I think...that the intersection of the palings and the rails should be on the boundary.
Thanks TDL, I'm not scared of my neighbour, I just mean that cos he is an engineer he is more likely to measure it
We had this problem where our neighbours stuffed up their garage and the fence was going to be 200mm on our land of course we kicked up a massive stink and it ended up only being 30mm on our land and the fence people showed us this document that says there is allowed to be an allowance of up to 50mm, thats in melbourne, which I think your in??
Hey,
Sweet, thanks for that Cosmos!
That was after I made them re-do post holes three times.
Our fencing contractor told us 60mm.
That was after I made them re-do post holes three times. 60mm I can live with. 2000mm was a bit much.
Ooooh yeah that's a lot 2000mm!!
2
Thank you @. Tried to play with the facade models but the exact colour is not matching up.
22/05/2023
3
Render your bathroom walls, two opinions versus the one, makes you wonder.
19/07/2023
8
thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover.
