Who has had this particular product installed and can you remember when the perimeter part was laid. eg. before or after timber, brickwork etc.
Mr. X
Browse Forums Building A New House Re: Kordon Perimeter Termite Treatment 2Dec 13, 2009 6:01 pm After the timber work, before the brick work. The stuff around the pipes that go through the slab was laid around the pipes before the slab was laid. Check out my blog for pictures. Re: Kordon Perimeter Termite Treatment 3Dec 14, 2009 1:43 pm netadelle After the timber work, before the brick work. The stuff around the pipes that go through the slab was laid around the pipes before the slab was laid. Check out my blog for pictures. As we thought. Checked the site and noticed it wasn't down yet. Is now being rectified, it pays to check things for yourself. Yes, unless you are in a low intensity rainfall area or the area is protected from rain. Do you have access to NCC Part 2 or can you download it? I can email you a copy… 10 12509 i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 12767 Yes, neither is termite damage that is not covered by your house insurance. 3 6575 |
