Browse Forums Building A New House 1 Jul 17, 2007 10:57 pm With slab down during the weekend, I've noticed (with the help of the lovely rain) that our slab is not 100% level. Puddles form on a number of different areas. Is this normal, or should a slab be 100% flat?
Does the unevennes mean the slab does not meet Australian Standards? Will this cause a negative effect down the track - i.e. tiling. etc. Basically what I want to know is whether this is a problem or am I just overreacting. The builder has already sent me an invoice for Base stage, and I'm really not sure which way to head - I don't want to approve payment if the job hasn't been done properly. Re: Slab has been poured 2Jul 18, 2007 6:28 am Hi Stewie, this question has been asked before, see here for some other replies
https://forum.homeone.com.au/viewtopic.p ... lab+puddle Our slab was pretty much level, the only puddles we had were in the bathroom areas near the pipe. I'd say we were just one of the lucky ones. Our Adenbrook home was completed in September. Hello everyone, I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters… 0 72341 Hello needing some advice. I was about to build my Alfresco and needed a new slab and remove exisiting slab as its not standard. So they start to excavate and jackhammer… 0 10701 You have mandatory building inspections and privately engaged building inspections. The difference between the two comes down to inspecting the building so it's safe and… 3 18076 |
