Browse Forums Building A New House 1 Nov 24, 2009 4:28 pm Hi all, We are building a Plunkett home in the WA suburb of Riverton. As the builder is doing our exposed agg. paths and driveway, I am going to dig in some conduits under the drive and paths, prior to them being laid for future electrical cables and irrigation pipes. I am having a few confliciting accounts of the type of conduit to use. I know that for irrigation I will use a 30mm white PVC pipe, dug in to a depth of about 300mm capped at both ends. However I am having trouble deciding what conduit to use for future electrical cables under the drive. I am aware they have to be 600mm underground which is fine, BUT what conduit do I use and what diameter would people recommend. I have heard you have to use orange for 240v elec cables? Then i will cap it at both ends and note location for future use by electrician. Any advice, or stories on what others have done would be appreciated. PS: sorry if this is in the wrong forum (it is about a new build) Re: What type of Conduit to "dig in" prior to driveway down 2Nov 24, 2009 7:23 pm A Good electrical supply joint can advise on cable conduit. I needed some for a adsl ( 35 meters to a rear block so laid it it when the main trench for sewer and water and gas and power was already doug ) put some string thru it for later convience. The telstar stuff had p20 I think on it and the word telstra so the electrical supply people got it right. (I checked with telstra before) cost $37 and took me about 30 mins. Happy building Timeline Aug 08-Land Mar 09-Demo/Titles Sept 10-Handover No1 Sept 11-Handover No2 April 12-Sold No2 Aug 14-Land/Demo Jan 15-Slabs viewtopic.php?f=31&t=25736 Re: What type of Conduit to "dig in" prior to driveway down 3Nov 30, 2009 6:55 am 2 comments: Yes power cables must be orange, it helps distinguish it from water based systems before you put your shove through it. A power conduit MUST be min 900mm under the surface.I strongly suggest you dig the trench, then put a layer of blue metal rock or red scoria rock 300mm over the conduit. This way when you are digging in the are, you will know you are near power, and how deep you are. Adrian B Re: What type of Conduit to "dig in" prior to driveway down 4Nov 30, 2009 6:59 pm Adrian B 2 comments: Yes power cables must be orange, it helps distinguish it from water based systems before you put your shove through it. A power conduit MUST be min 900mm under the surface.I strongly suggest you dig the trench, then put a layer of blue metal rock or red scoria rock 300mm over the conduit. This way when you are digging in the are, you will know you are near power, and how deep you are. Conduits buried for electricity are to be, minimum 500mm from top of conduit to ground level, orange in color and have the indicative tape buried above it (available from wholesalers) Re: What type of Conduit to "dig in" prior to driveway down 5Nov 30, 2009 7:01 pm Adrian B 2 comments: Yes power cables must be orange, it helps distinguish it from water based systems before you put your shove through it. A power conduit MUST be min 900mm under the surface.I strongly suggest you dig the trench, then put a layer of blue metal rock or red scoria rock 300mm over the conduit. This way when you are digging in the are, you will know you are near power, and how deep you are. Conduits buried for electricity are to be, minimum 500mm from top of conduit to ground level, orange in color and have the indicative tape buried above it (available from wholesalers) Re: What type of Conduit to "dig in" prior to driveway down 6Nov 30, 2009 10:38 pm Dylan Adrian B 2 comments: Yes power cables must be orange, it helps distinguish it from water based systems before you put your shove through it. A power conduit MUST be min 900mm under the surface.I strongly suggest you dig the trench, then put a layer of blue metal rock or red scoria rock 300mm over the conduit. This way when you are digging in the are, you will know you are near power, and how deep you are. Conduits buried for electricity are to be, minimum 500mm from top of conduit to ground level, orange in color and have the indicative tape buried above it (available from wholesalers) indicative tape buried 100mm above it Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: What type of Conduit to "dig in" prior to driveway down 7Apr 06, 2016 12:17 pm Im a sparky. 500 mm in free ground. Under concrete driveway it can be directly under or in it, we normally scratch it in. 300mm under paving. Orange for 240volts or if its just for extra low voltage garden lighting it can be gray and put at any depth the conduit would need to be undamaged regardless of what network is in play. The conduit needs to be able to have fibre run through it. NBN and Opticomm are just… 4 2882 Natural stone tiles like slate, travertine, and limestone add a timeless, elegant look to… 0 24591 2 4181 |
