Browse Forums Building A New House 1 Nov 21, 2009 8:50 am Can someone please explain the rules regarding having eaves or verandahs over boundary setbacks. Our block has a four metre setback at the front. I think this means that the front house wall needs to be four metres back from the footpath but I'm not sure about the portico or verandah. We have to have a verandah or portico taking up at least 40% of the house frontage. So does this mean that the verandah and it's pillars can be within the four metres setback ie around three metres from the footpath? We also have a one metre setback from the side boundary. Does this mean that the wall has to be one metre from the fence but the eave can be over this one metre boundary? We have a reasonably small block and will be filling most of the available room with house or alfrescos. Just trying to get our heads around the rules. We have a huge garden at the moment and are looking forward to having something much more manageable. Re: Rules regarding eaves / verandahs over boundary setbacks 2Nov 21, 2009 8:54 am Our house is set back 5m from the front boundary, this is to the post in our portico (it doesn't include our 450mm eaves). Also our side boundary must be 2m in, this again is 2m to our external wall, not including our 450mm eaves). Hope that helps - probably best to clear it with either council or the developer where you are. Re: Rules regarding eaves / verandahs over boundary setbacks 3Nov 21, 2009 8:58 am Thanks aaron4erin. That's what I thought might be the case with the front pillars. We'll factor that in in our plans and work on worse case scenario. Re: Rules regarding eaves / verandahs over boundary setbacks 4Nov 21, 2009 9:05 am Hi, You don't say where you are however, check your local council's website for a DCP. That should explain it all in waaaaaay to much detail!!! Pix Built a (highly) modified Allcastle Maxworth 38.7 in Sydney. Re: Rules regarding eaves / verandahs over boundary setbacks 5Nov 21, 2009 9:22 am Pix is right, it depends on where you are. Rules can vary a lot between states and between councils, and even between housing estates in the same municipality. Our minimum setback was 5.5m for garage, and 4.5m for house, but did not include porticos or verandahs, which were allowed to be 3m from the front boundary. Some lots in our estate have different requirements - those on the main road require a minimum 6m setback and corner blocks and those facing or backing onto some reserves have some different restrictions too. The one metre minimum side setback usually includes eaves. You may be able to build right to the boundary on one side for a certain distance too. That's usually the case with garage side walls, but you'd have to have no eaves and a recessed design for the spouting along that wall. I'd check with your council before doing any work on designing the house - otherwise you may have a lot of disappointment in store. Re: Rules regarding eaves / verandahs over boundary setbacks 6Nov 21, 2009 11:43 am We had the same issue with our corner block - balcony on one side, porch on the other. Developer said we could build within the setbacks and got preapproval of plans. However our final contract got rejected at Council - something to do with the height vs distance from road and we had to re-site the house 0.5m back on each side! Corner block, lake view, custom design Re: Rules regarding eaves / verandahs over boundary setbacks 7Nov 21, 2009 11:53 am kek The one metre minimum side setback usually includes eaves. You may be able to build right to the boundary on one side for a certain distance too. That's usually the case with garage side walls, but you'd have to have no eaves and a recessed design for the spouting along that wall. I'd check with your council before doing any work on designing the house - otherwise you may have a lot of disappointment in store. Yep same as us, we had to delete the eaves from our plans as they encroached on the 1m boundary otherwise. Caz & Co ALL MOVED IN!! Now comes all the hard work-decorating.... [b]Blog: http://cazoraz.blogspot.com/ Settling in Thread: viewtopic.php?f=31&t=36993 My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 6936 1 1927 "is it exempt or do I need to get permission from council" Call your Council and ask them 1 1583 |
