Browse Forums Building A New House Re: Rules regarding eaves / verandahs over boundary setbacks 7Nov 21, 2009 11:53 am kek The one metre minimum side setback usually includes eaves. You may be able to build right to the boundary on one side for a certain distance too. That's usually the case with garage side walls, but you'd have to have no eaves and a recessed design for the spouting along that wall. I'd check with your council before doing any work on designing the house - otherwise you may have a lot of disappointment in store. Yep same as us, we had to delete the eaves from our plans as they encroached on the 1m boundary otherwise. Caz & Co ALL MOVED IN!! Now comes all the hard work-decorating.... [b]Blog: http://cazoraz.blogspot.com/ Settling in Thread: viewtopic.php?f=31&t=36993 My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 7137 1 2031 "is it exempt or do I need to get permission from council" Call your Council and ask them 1 1873 |
