Browse Forums Building A New House Re: Building Process - Sequence of events 2Nov 21, 2009 7:55 am Before your slab is poured, there is site scrape, plumbing set out, etc. After slab...... many of these are interchangable and I've probably missed heaps. Frame Windows Guttering, fascia Sisalation Roof Plumbing rough in Electrical rough in Bricks Heating/cooling rough in Insulation Lock-up carpenter (wall straightening, hang external doors) Plaster Eave lining (if applicable) Cabinetry Fix carpenter(hang internal doors, skirting, architrave, cornice) Paint Tiling Garage doors Electrical fit off (lights, light switches) Heating/cooling fit off Plumbing fit off (taps, toilets) Final carpentry fix (door handles) Robe/shelving fit offs Render (if applicable) Downpipes Shower screens, mirrors Final kitchen fit off (benchtops, glass splashback) Appliances Hot water unit install Carpet There'll be site cleans intermittently (we've had 4 so far) Is that it?? What have I missed? I leave you to fend for yourself, figure things out yourself. Terrence Malick I apologise for any confusion, but your understanding is correct. We approached our situation differently based on advice from… 11 53211 Thanks very much! And would the landscaper/contractor generally involve the engineer or is that something the client would do? Thanks for your help 2 10025 The most definitive answer to your question James is this taken from the James Hardie Axon Cladding Installation Guide - i just happen to have it… 5 3667 |
