Browse Forums Building A New House 1 Nov 17, 2009 5:41 pm I need to buy 55m of 2.4m Fibre Cement fencing with capping. For that amount of fence, where would be the best place to buy it? Just Bunnings? Or a supplier? And can you buy it second-hand, and if so where? It doesn't have to be new, as it will be put up while the building continues (hopefully ASAP) and if there is an opportunity to buy it second-hand I would prefer that in case it gets damaged. The house is in Perth (NOR), but as I work in Newman FIFO I don't have much time in Perth to drive around and source the best price/etc. Thank you so much! EDIT: Sorry I found out it's Fibre Cement, and it's not the standard HardiFence as it has 6 ripples in it, not 5, so edited the post. What is the one wtih 6 ripples in it called? Re: Buying Fibre Cement Fencing 3Nov 18, 2009 7:14 pm I am probably not much help for you and I just have a run in with this whole FC stuff (its on my thread ), I have a situation where the architect (in their so called wisdom) specified FC panels for the balcony and we now need to be looking at CFC panels (Compressed Fibre Cement) as they come in longer lengths - it could be just a particular scenario with us but maybe worth for you to check out too progress viewtopic.php?f=31&t=20401 sculptures viewtopic.php?f=36&t=26607 pole trouble viewtopic.php?f=3&t=25988 Re: Buying Fibre Cement Fencing 4Nov 19, 2009 9:15 am Thank you for replying! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Just to post the solution in case it helps someone else, we are going through this mob: www.aussiefencing.com Someone at work recommended them, so I sent them a email for a quote last night, and they got back with a great quote (for capping and fencing it came to the same price after I called places in Perth for fencing alone) and the delivery is very cheap too considering it's 1.9 tonnes of fencing... DIY, Home Maintenance & Repair All my inside walls are Fibre Cement & House has Steel frames... Tricky when one wants to hang pictures or do Wainscoating Paneling up the hallway. Those little nail… 0 3161 Approvals are covered in the cost we are paying to the pool company. The only thing stated in our home build contract for the additional cost is engineering support. … 3 7137 Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4495 |
