Browse Forums Building A New House Re: Has anyone used a good private builder in Adelaide? 9Nov 22, 2009 8:33 pm Thanks for all the feedback. Very helpful. Has anyone build with Dado before? If you already have a contract, is the inspection cost stated in there? If not they would be forced to issue you a variation which you could of course object to. 12 25889 Building a new home, and looking for a garage builder (home builder not contracted to do this). Someone to build steel garage (double), colorbond, including supply and… 0 3257 there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18306 |
