Browse Forums Building A New House Re: Solutions to frame overhang. 21Nov 22, 2009 3:10 pm It is not being fussy or picky, it is making sure your builder is doing what you contracted and pay them to do. Should you breach your contract in any way they would be the first to wave the contract in your face. Fussy and picky would only be if you asked for perfection and not accepted standards & tolerances. Re: Solutions to frame overhang. 22Nov 22, 2009 3:25 pm Quote: The way I see it accepting a house (that cost you a quarter of a mill) that has pretty major 'not-what-we-ordered' defects like bent walls or extreme slab overhang, would be like taking delivery of a brand new 250k Ferrari with a dent in the door and saying, "yep I'll take it, that dent looks grouse. Thanks." As if you would. As long as the dent is with in a 10mm tolerance it should be OK. Cheers KW................ “It's just as unpleasant to get more than you bargain for as to get less” George Bernard Shaw. Re: Solutions to frame overhang. 23Nov 22, 2009 3:31 pm Sometimes the last bit seen is soo very minimal to the scope... A supplier once said to me after an issue I raised with the client, "People don't even know what you are doing so how would they know what is right or not" ... so that ended that relationship The knowledge base of the individual ( and Job specific associates) decide the path of progress. If a repair becomes necessary then it will be carried out by the most capable person available. If you are a grano then that is your trade but repairing it is a whole new ball game with many pieces of equipment you would hope they are using HOW MANY TIMES A bit like a carpet layer.. Likely doesn't clean carpets Ash will correct my analogy This is where the senior needs to visit a site to draw the correct conclusion. ...and implement the correct procedure or outsource the repair Seems we forgot about the swings n roundabout for a buck Where you are coming from is where you are going to... Re: Solutions to frame overhang. 24Nov 22, 2009 3:51 pm Quote: "People don't even know what you are doing so how would they know what is right or not" Thats the great thing and what I like so much about HomeOne. There are plenty of people who are willing to share their knowledge about building practices. Offer opinions and make surgestions. At the end off the day we all want the same thing " what we have paid for" no more but no less. Regards to all KW.................. “It's just as unpleasant to get more than you bargain for as to get less” George Bernard Shaw. In the end, two pieces of treated timber (20mm thick) were bolted onto the joists and planed when there was too much sticking out. Passed inspection. 13 7790 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 3796 I would find out how deep your clay base is and depending on the depth install a cut off drain which is more than a normal agi drain. Where the neighbouring walls is… 2 3147 |
