Browse Forums Building A New House 1 Nov 13, 2009 5:00 pm Hi Guys, To cut a long story short the concrete guys poured a little bit too much on the porch and was instructed by the SS to chip away 150mm. The guy did a pretty reasonable job except he chipped a bit too much on the edge. I have attached a photos for your reference - is this overhang something to worry about ? thx Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Slab Fix Up - Frame Over Hang 4Nov 13, 2009 10:01 pm Geez what is wrong with a quickcut and a hammer. That had no need to be rough it could have nice been smooth. ... ... some of these guys have too much braun and not enough brain Get some epoxy mortar concrete repair to fix it don't render it, because soon enough about 2 seasons it will fall off. Where you are coming from is where you are going to... Re: Slab Fix Up - Frame Over Hang 5Nov 14, 2009 6:00 am Hi All, Thanks for all the inputs. The brickwork is scheduled to be done next week and hence will "cover" up this area. I'm guessing this should be all okay ... ? DIY, Home Maintenance & Repair Ditto 3M Claw, expensive but best thing I've used to date. I put two of the 11kg ones in for a 12kg mirror on the wall, and its been great for 4 years now. 4 2131 This is 100% true. You can not hang anything on steel frames. very frustrating 8 8004 One corner of my shed slab will be directly over a 1400mm diameter concrete soakwell. Is it feasible to fill the soakwell with concrete then lay the shed slab over the… 0 651 |
