Browse Forums Building A New House 1 Nov 10, 2009 6:24 am We are building our first home, can anyone tell me approximately how much you pay per square metre for a carpenter to build frame and install insulation in Sydney? I have no idea of the cost of brick veneer versus double brick Re: Cost of Brick Veneer versus Double Brick? 2Nov 10, 2009 6:55 am it will depend on the amount of brick you require as well as on it's quality. The price difference could be quite a few $ per brick. This should be a good starting point: http://www.boral.com.au/brick_calculato ... ckinsights ... built a Promenade with Clarendon. viewtopic.php?f=31&t=25104 20-10-09 - excavation and piering completed ... 12-04-10 - Basins fixed. Connecting to the electrical grid 23-04-10 - PCI 07-05-10 - HANDOVER! Re: Cost of Brick Veneer versus Double Brick? 3Nov 10, 2009 11:41 am From what I can gather, it doesn't cost much more to go from brick veneer to full brick. But for price comparison, you must stop right there. However, usually once you have full brick this is followed up with a suspended concrete slab. Very nice, but also expensive. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Cost of Brick Veneer versus Double Brick? 6Nov 11, 2009 11:52 am mandystoj I was quoted arond 100k more for full brick for just over 60squares (duplex). Is that with a suspended concrete slab? Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Cost of Brick Veneer versus Double Brick? 7Nov 11, 2009 11:56 am mandystoj I was quoted arond 100k more for full brick for just over 60squares (duplex). I was quoted the same, by a project home builder for a double storey 35 square house. Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Cost of Brick Veneer versus Double Brick? 8Nov 11, 2009 1:17 pm Casa2 mandystoj I was quoted arond 100k more for full brick for just over 60squares (duplex). Is that with a suspended concrete slab? No suspended concrete slab. It was just preliminary quotes to see if the duplex my arhitect was drawing up was't going to cost us over 800k. Went over 800k with double brick. DA approved Waiting on a few more Builder's quotes. Re: Cost of Brick Veneer versus Double Brick? 9Nov 11, 2009 6:50 pm mandystoj Casa2 mandystoj I was quoted arond 100k more for full brick for just over 60squares (duplex). Is that with a suspended concrete slab? No suspended concrete slab. It was just preliminary quotes to see if the duplex my arhitect was drawing up was't going to cost us over 800k. Went over 800k with double brick. It was the suspended concrete slab that put you over budget. Double brick with the same floor as a brick veneer would be a lot cheaper. Demolition August 2009, Construction Started September 2009, Completed December 2010 5 10476 2 8358 can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 4461 |
