Browse Forums Building A New House Re: Colourbond vs Tiles 21Nov 10, 2009 8:45 am Personally I think it depends on the house and the look you are trying to achieve. My Better Half and I chose tiles, I have seen the same house we are building but done with a colorbond roof and it looks very different. My builder did not charge extra or less for a colorbond roof. Re: Colourbond vs Tiles 22Nov 10, 2009 2:15 pm if you are going for colorbond then make sure you prevent any access to the indian maynas to go under the roof. They are notorious in getting into the colourbond roofs and cause major damage and health hazard not to mention the noise in the celing - i am talking from experience Masterton Crystal MK1 Split Level Blacktown CC Paid $2.5k end Sept; Frame 14 Apr; viewtopic.php?f=31&t=32025&hilit=ekman Re: Colourbond vs Tiles 23Nov 20, 2009 11:05 am We are having a quote done at the moment for a new house, the initial quote was $8000 more for colorbond over concrete tiles. But then the builder suggested a simpler design for the roof - shallower pitch, no hips & valleys etc, and it came in at the same price. Something to do with "roof plumbing" being more complicated when using colorbond. Anyway we will have to see the elevations to see if the house will look like a shed! Re: Colourbond vs Tiles 24Nov 20, 2009 1:10 pm ekman if you are going for colorbond then make sure you prevent any access to the indian maynas to go under the roof. They are notorious in getting into the colourbond roofs and cause major damage and health hazard not to mention the noise in the celing - i am talking from experience Can you tell me what happened ekman, we have mynas making a nest in our roof already! they have already pulled out bits of insulation think I had better call....MESHMAN Re: Colourbond vs Tiles 25Nov 20, 2009 2:05 pm Helyn That's interesting - most posters from eastern states have said colourbond is dearer and many pay thousands to upgrade to it. In SA, colourbond doesnt seem any dearer than tiles though In term of the price itself, I would imagine colorbond should be dearer as metal has to be treated twice before the complete product is produced whereas with tile, once is enough. Some designers suggest tile is a more expensive option because it is heavier so structural requirement has to be increased. But with project builders, tile roof is always the base finish therefore the structural side of it will not matter (the structure could take tile then it has no problem taking colorbond); the extra money you are paying to upgrade to colorbond is simple the difference in prices I reckon. I myself find colorbond is a better choice cosidering different factors including the look, low maintaince, longer life... Yes i guess this is one of the main reason as i checked one post foundation 4 9997 Cheers. The painted render is a bit chalky to the touch. To prepare the surface for best adhesion, what would you recommend? Also, given that there must be some… 6 8513 Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 7793 |
