Browse Forums Building A New House 1 Nov 04, 2009 7:00 pm I have chosen a floor tile which is almost excactly the same as stipple seal laminex. Do I 'have' to have a carpet colour similar?? The carpet I have orignally chosen is much lighter, but a very natural/neautral colour. Im not sure if there are 'rules' with this or if it will look 'wrong' We are thinking floorboards to. so tiles are only in wet areas, but obviously the carpet needs to blend with the floorboards AND the tiles. Not sure if it should be light tile dark carpet, or dark tiles light carpet, or the same ?? Any advice? Thanks Once all this is over with I will be happy for it to just be built Re: should floor tiles and carpet be almost the same colour? 2Nov 04, 2009 7:09 pm Were going to go with a darker/redder timber floor so our rumpus carpet will be lighter in colour but hard wearing.. If I was having lighter tiles Id probaby go with darker carpet and vise versa... Re: should floor tiles and carpet be almost the same colour? 3Nov 04, 2009 7:15 pm makoby i also chose stipple seal for vanities in bathrooms and a very close floor tile. my carpet is alot lighter but is a natural tone which makes it work quite well. my suggestion would be to get samples of each and put them next to eachother including the wall colour. this will give you a better idea if it works together, sometimes the colours appear different when next to eachother or in different light so try to take it to the site and see. must say im happy with the vanities and tiles matching in my place, it works really well. yours sould like it will be fine. Re: should floor tiles and carpet be almost the same colour? 4Nov 04, 2009 7:18 pm We're using creamy coloured tiles and a mid to dark brown carpet. We liked the contrast, but it's a bit simpler for us because we didn't have to match tiles and floorboards! I think if you go with a neutral colour then it should look good. Go with your instincts - in the end you have to be happy to see it everyday! Re: should floor tiles and carpet be almost the same colour? 5Nov 04, 2009 7:36 pm Another one here that has stipple seal cupboards (kitchen) we have chosen kempas floorboards for kitchen floor and dining area and the two loungerooms that come off them the carpet is chocolate. makoby I have chosen a floor tile which is almost excactly the same as stipple seal laminex. Do I 'have' to have a carpet colour similar?? The carpet I have orignally chosen is much lighter, but a very natural/neautral colour. Im not sure if there are 'rules' with this or if it will look 'wrong' We are thinking floorboards to. so tiles are only in wet areas, but obviously the carpet needs to blend with the floorboards AND the tiles. Not sure if it should be light tile dark carpet, or dark tiles light carpet, or the same ?? Any advice? Thanks Once all this is over with I will be happy for it to just be built No! I don't belive you "have" to at all, do what you feel comfortable with. Building Thread viewtopic.php?f=31&t=13002 Site start: 8th July 2009 Handover: 11/12/2009! 5 months total build time. 40 sqs of luxuary...Bliss! Re: should floor tiles and carpet be almost the same colour? 6Nov 04, 2009 7:39 pm dilla We're using creamy coloured tiles and a mid to dark brown carpet. We liked the contrast, but it's a bit simpler for us because we didn't have to match tiles and floorboards! I think if you go with a neutral colour then it should look good. Go with your instincts - in the end you have to be happy to see it everyday! +1 - our tiles will be creamy/beige and the carpet medium choc brown, yes they contrast but also compliment each other. Caz & Co ALL MOVED IN!! Now comes all the hard work-decorating.... [b]Blog: http://cazoraz.blogspot.com/ Settling in Thread: viewtopic.php?f=31&t=36993 1 15694 Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 7232 They make the room much easier to clean for one, reflect more light (if light colour tiles are used), and you dont end up with dust on the top edge of tiles (cause most… 3 9539 |
