Browse Forums Building A New House 1 Oct 29, 2009 3:02 pm Hi, just running it past you. We have just received a progress payment for our plaster set, this is the last progress payment we make before PCI amount. My concern is that our ground floor render has not been completed ... only just the rough coat done, waiting for the sealer then acrylic render. Do you think we have the right to hold back payment until this has been completed, or the fact that the internal plaster work has been done, we have to pay. My concern is, that the final PCI amount is not that much, and thus they lose the incentive to get a move on with our job ... which has already dragged out ... Thanks. Re: Progress Payment Claim 4 plaster set but external not finish 2Oct 29, 2009 3:17 pm If you are at "lock-up", which will be defined in your contract, then "no", it's not ok to hold off payment. Our lock up invoice was issued once all plaster was completed (no bricks) and you technically couldn't get inside unless you damaged walls. Hope this helps. Building Thread viewtopic.php?f=31&t=13002 Site start: 8th July 2009 Handover: 11/12/2009! 5 months total build time. 40 sqs of luxuary...Bliss! Re: Progress Payment Claim 4 plaster set but external not finish 3Oct 29, 2009 3:51 pm I would think plaster set was the inside plaster... not outside render. Normally you have 10 days to pay the bill, maybe the render will be done by then If you are not sure what's included at plaster set stage, maybe ring the builder just to clarify. The invoice would have been generated because on the system the stage of plaster set has been 100% complete.. info normally given on a weekly basis by the supervisor. Built with New Generation (Summit Homes) We own land!... with a slab on it! Plus a shell of a house with stuff inside ! 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 4439 Hi there, long-time lurker but first time posting. I've bought a house 2 and a bit years ago and last year we had some major water damage on a converted pergola area… 0 8003 I apologise for any confusion, but your understanding is correct. We approached our situation differently based on advice from… 11 53793 |
