Browse Forums Building A New House 1 Oct 28, 2009 7:16 pm Hi am just wondering if anyone has any recommendations on vacuum systems, we are considering including this in our build but as we have already signed contracts need to make decisions ASAP. We are building a 2 storey home with a project builder and they use a Hills CentralVac 1600w as their standard. I am wondering whether or not this would be sufficient for a 2 storey home with the second storey being mainly carpet. Or should I get some other quotes and see if the builders are agreeable to taking this out of contract. Any tips much appreciated. Re: Advice on Vacuum Systems 2Oct 28, 2009 9:38 pm Hi We're building a 2-storey home too with generally all carpet upstairs. I think our system that comes standard with our house is 2HP, but when speaking to the company installing our system, they've recommended that we upgrade to a 2.75HP system (they said to budget about $300 to upgrade this). Hope this helps! Re: Advice on Vacuum Systems 3Oct 28, 2009 10:12 pm When researching the same thing, we were told by several ducted vacuum companies that the airflow is the critical specification and that to service our 34 square 4 bed dbl storey house, we would need a system with an air output of 550 atleast. Ring a couple of companies, give them the no or squares of your house & the number of rooms and see what they say. Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18129 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7012 |
