Is it possible to transfer to my rental property or freeze my landline number during the construction period ?
Thanks
Browse Forums Building A New House 1 Oct 28, 2009 1:41 pm Is it possible to transfer to my rental property or freeze my landline number during the construction period ? Thanks Re: Keeping same landline number ? 2Oct 28, 2009 1:54 pm I think you can take your number with you from your current house to your rental to your new house, as long as you are staying within the same postcode. Re: Keeping same landline number ? 4Oct 28, 2009 2:08 pm As long as you remain connected to the same exchange when you are moving, then you should be able to keep the same number. Then it just becomes an issue that is dependant on your service provider, whether you change or stay with them. We didn't move very far, but it was far enough to lose broadband access which means we had to change providers and move to cable for internet. Good Luck! Cheers, CMET Re: Keeping same landline number ? 5Oct 28, 2009 2:18 pm dilla I think you can take your number with you from your current house to your rental to your new house, as long as you are staying within the same postcode. It is going to be a different postcode. Re: Keeping same landline number ? 6Oct 28, 2009 2:19 pm gkj001 Yes, we knocked down our house and rebuilt and we asked Telstra to hold our number. Awesome Re: Keeping same landline number ? 7Oct 28, 2009 2:24 pm CMET As long as you remain connected to the same exchange when you are moving, then you should be able to keep the same number. Then it just becomes an issue that is dependant on your service provider, whether you change or stay with them. We didn't move very far, but it was far enough to lose broadband access which means we had to change providers and move to cable for internet. Good Luck! Cheers, CMET I will be losing internet too...will have to join a new plan and loss some $$$ since most internet plans are 12 months contracts Re: Keeping same landline number ? 8Oct 28, 2009 2:35 pm vincy dilla I think you can take your number with you from your current house to your rental to your new house, as long as you are staying within the same postcode. It is going to be a different postcode. yet if it isi on the same Telephone Exchange (the thing that really matters) then you can keep your number only if you move from that exchnage then you will geta new number.. also not that any BB service other then cable will be let loose and if your exchnage had limited ports you may be with out BB when you reconnect Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Keeping same landline number ? 9Oct 28, 2009 3:39 pm The stress of building and moving I need the internet since i run a home business Re: Keeping same landline number ? 10Oct 28, 2009 4:37 pm Another option is to port the number out to a VOIP provider. This gives you number portability between exchanges, and can potentially reduce your phone bills too + the number stays alive even when you don't have a phone service. Gotalk will port out a number - I think it cost me about $10 a couple of years ago + a monthly call plan. David Re: Keeping same landline number ? 11Oct 28, 2009 5:46 pm vincy The stress of building and moving I need the internet since i run a home business Me too Vincy.... plus we'd had our home number for 22 years and I didn't want to change it. I'm too old to remember a new number. Luckily we were building within the same exchange area, and managed to find a rental there too. So our phone number came with us through two moves without any drama at all. No issues with broadband either, we were reconnected both times within two or three days (I managed with dial-up or the wi-fi at the local Macca's in the meantime ) .... although I hear that others in my area weren't so lucky. Looks like our timing was just perfect. Appreciate that Chippy. I won’t do sand under pavers and will connect all up under pavers, however I was going to do: 1) Roadbase compacted with manual hand tamper 2)… 10 18530 |
