Browse Forums Building A New House 1 Oct 25, 2009 6:41 pm I have been looking at the wiring in the new house and I noted a small electrical juntion box that I guess inside has some wires joined together using screw terminators. The ceiling space will be inaccessible once it is complete. Is this an acceptable practice? Does the building code allow this or the Wiring rules for that matter? Has anyone else had this? Thanks dan Re: Junction box in a closed ceiling space 2Oct 25, 2009 7:38 pm very common practice nothing to worry about Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Junction box in a closed ceiling space 3Oct 25, 2009 7:42 pm If you are worried about a junction box up there, don't freak out about all the houses that have ducted heating units up there! 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: Junction box in a closed ceiling space 4Oct 25, 2009 7:42 pm Even if it is in an inaccessible place, ie I can see that the place where it is will be gyprocked over. I guess i woudl have thought that the AS3000 wiring rules may have said something about that. Regards Dan Re: Junction box in a closed ceiling space 5Oct 25, 2009 8:12 pm lisanne If you are worried about a junction box up there, don't freak out about all the houses that have ducted heating units up there! Lisa, Looks like that was your 5000th post, yeah!! Re: Junction box in a closed ceiling space 6Oct 25, 2009 8:33 pm vid lisanne If you are worried about a junction box up there, don't freak out about all the houses that have ducted heating units up there! Lisa, Looks like that was your 5000th post, yeah!! LOL you keep a closer eye on that than I do! 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure There may be answers here but can't find anything. I have a closed in veranda, four windows. North facing, just had sunblock blinds installed. A bit cooler (actually… 0 2982 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28819 I brought terry road box hill in June 2022 House was meant to be completed Nov 2023 That did not happen I had to chase them so much to the land Registration and… 0 2519 |
