Browse Forums Building A New House 1 Oct 24, 2009 5:22 pm I got a bill from the water corp yest for our vaccant land (no slab yet!) and to my suprise i have a connected meter with tap that is being used!!! i think its the builders next door who have a slab but no tap. ill call them on monday and ive left a note, but is there anything else i can do?? the water corp wont help me Building the Pegasus New Generation Bletchley Pk, Southern River Land purchased 03/2009 Contract 06/2009 Prestart 09/2009 Land cleared/sand Pad 10-12-09 Fittings done 17-12-09 SLAB!! 18-12-09 Brickies started 27-1-10 Roof Started 2-3-10 Lock Up 13-5-10 Re: Water meter 2Oct 24, 2009 5:25 pm ladsos I got a bill from the water corp yest for our vaccant land (no slab yet!) and to my suprise i have a connected meter with tap that is being used!!! i think its the builders next door who have a slab but no tap. ill call them on monday and ive left a note, but is there anything else i can do?? the water corp wont help me Ok I had a similar problem, I had a tap and so did my neighbour, when my slab got poured they used his tap and mine. The neighbour threw a tanty of all tantys and abused the hell out of me He then rang the water corp and they reset his meter! Then, the moron got his slab poured and tried the same trick again the water corp didn't reset it as it was his slab that used the water Maybe try calling them again Building with Homebuyers Centre El Questro! My building thread..viewtopic.php?f=31&t=19421 Brickies started 5/10 Re: Water meter 3Oct 24, 2009 5:46 pm thanks Lynne, im pretty subborn and a #1 complainer so watch out water board! Building the Pegasus New Generation Bletchley Pk, Southern River Land purchased 03/2009 Contract 06/2009 Prestart 09/2009 Land cleared/sand Pad 10-12-09 Fittings done 17-12-09 SLAB!! 18-12-09 Brickies started 27-1-10 Roof Started 2-3-10 Lock Up 13-5-10 Re: Water meter 4Oct 24, 2009 5:48 pm good for you hopefully you will get a different person that actually helps you next time you call them Building with Homebuyers Centre El Questro! My building thread..viewtopic.php?f=31&t=19421 Brickies started 5/10 Re: Water meter 5Oct 24, 2009 6:29 pm Easy solution for your next billing period, especially if construction of your home hasn't started yet. Remove the tap. Re: Water meter 8Oct 24, 2009 7:49 pm It's only costs $1 per 1000 litres of water. I would stop stressing. The supply charge should be more expensive than the actual usage. Thanks for sharing. Looks good. The joiner has come back with a quote of close to 5k. I think we are going to not do it. Attaching panelling is something they are dead… 11 10088 18 74553 |
