Browse Forums Building A New House 1 Oct 23, 2009 8:50 pm Hello out there. I am a fresh starting out owner builder and i have just purchased my first property, without fully understanding all the associated problems with a rear sloping site. The site slope approximately 4m, over a distance of 50m. The problem is with the stormwater. There are NO stormwater pits on my side of the street. There is however at the rear of the site a service lane way, not sure if it is an easement, which does have a 12' stormwater pipe to cater for an old townhouse development. ( not intruding on an development or blocks) If i cannot get access to this service lane way, could someone please tell me what other solutions i could do. Am i able to make the site fully storm water sufficient through use of storm water tanks and overflow detention pits etc... Am i able to raise the houses and cut the gutter to drain onto a downward sloping street. I am loosing many nights sleep over this issue, and i haven't even contacted council yet. I would sincerely appreciate if somebody could give me some advise in this regard. Much appreciated! Re: Stormwater solutions for backwards sloping site 2Oct 23, 2009 11:49 pm Hmmm... water is a biggy. But it is your friend if you can use it. It wouldn't be north facing slope? I might have a few ideas if you want to PM me. Onc Where you are coming from is where you are going to... Re: Stormwater solutions for backwards sloping site 3Oct 24, 2009 12:13 am Spend $12000 for stormwater pipes a sump and a pump. I have the same problem, council would not allow me to raise my house. The stormwate from your house is fine, as it is higher than the road and will drain, its only the paved areas that you will have problems with, so option 2 is have no paved areas. Re: Stormwater solutions for backwards sloping site 4Oct 24, 2009 12:17 am It might be possible to have a more visually pleasing result. Where you are coming from is where you are going to... Re: Stormwater solutions for backwards sloping site 5Oct 24, 2009 6:51 pm onc_artisan It might be possible to have a more visually pleasing result. Yeah that the $12,000 option. Re: Stormwater solutions for backwards sloping site 6Oct 26, 2009 9:55 pm buildingwithhamra Spend $12000 for stormwater pipes a sump and a pump. I have the same problem, council would not allow me to raise my house. The stormwate from your house is fine, as it is higher than the road and will drain, its only the paved areas that you will have problems with, so option 2 is have no paved areas. thanks for the reply. i am sorry if i don't understand. but my house is lower than the street. can this method still be achieved. Are you able to tell me what council wouldn't let you lift up the house. Re: Stormwater solutions for backwards sloping site 7Oct 27, 2009 8:36 am cbscon buildingwithhamra Spend $12000 for stormwater pipes a sump and a pump. I have the same problem, council would not allow me to raise my house. The stormwate from your house is fine, as it is higher than the road and will drain, its only the paved areas that you will have problems with, so option 2 is have no paved areas. thanks for the reply. i am sorry if i don't understand. but my house is lower than the street. can this method still be achieved. Are you able to tell me what council wouldn't let you lift up the house. Yep , my house is 20cm lower than the street in one corner and 5cm lower at the other, and port adelaide enfield would not let me lift it. I did ask to raise it 30cm as this would alleviate the need for a sump and pump, but no they said do what the engineer said, which was dig it into the ground. If you spend $$$ on a sump and pump, the stormwater runs to your sump (downhill - usually at the back of the block)and the pump, pumps it uphill to the street. In the end, two pieces of treated timber (20mm thick) were bolted onto the joists and planed when there was too much sticking out. Passed inspection. 13 7823 I would find out how deep your clay base is and depending on the depth install a cut off drain which is more than a normal agi drain. Where the neighbouring walls is… 2 3148 Howdy all. I am looking for feedback on what people would do to maximise and make an area as flat as possible. First, out the front of the house is a sloping hill, pretty… 0 20165 |
