Browse Forums Building A New House Re: What is the best product to get off grout from tiles? 2Oct 21, 2009 8:27 pm goto a concrete tool or bricklaying toll shop and ask for a product called liquid hammer or equivelant. it attacks the flyash in cement and dissolves it. Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: What is the best product to get off grout from tiles? 3Oct 21, 2009 11:22 pm Hubby was doing some regrouting yesterday. So I was wondering the very same thing! We also have some grout (or maybe tile glue?) from when the house was built. It sort of blended in with the texture/pattern of the tiles and over the years we've noticed a bit here and a bit there. I don't know what's worse, paying someone to do a sloppy job or having hubby do an amateurish job. Re: What is the best product to get off grout from tiles? 5Oct 21, 2009 11:28 pm Macy are you talking Liquid hammer? It might etch your glass, not sure. I guess it would be better to ask the supplier. Where you are coming from is where you are going to... Re: What is the best product to get off grout from tiles? 6Oct 21, 2009 11:47 pm jspitz On our balcony there seems to be some excess grout on the faces of some of the tiles-is there a product to get it off at all? How long has the grout been there? Has the grouting recently been done? What kind of tiles are they? Ceramic? and most importantly.... what type of grout is it? All these things can effect what is appropriate to use to remove the grout residue. Ash. Re: What is the best product to get off grout from tiles? 8Oct 22, 2009 10:13 am we have recently just tiled and grouted our new house post handover ourselves and found that small amounts of the grout were easily removed with metho and water and a bit of elbow grease anything big and thick we used a small scraper/scourer and then metho and water.... 2nd build here we come in Whittlesea! https://forum.homeone.com.au/viewtopic.php?f=31&t=92617 1st Build - Henley - Cooper in Doreen! (2009) https://forum.homeone.com.au/viewtopic.php?f=31&t=17354 Re: What is the best product to get off grout from tiles? 11Oct 22, 2009 8:07 pm OK, Get some cotton wool and a bowl of white vinegar. Place a bit of c/wool soaked with vinegar onto the actual grout residue, (BUT AVOID GETTING THE VINEGAR IN THE GROUT JOINTS). After the vinegar has soaked the grout for about 5-10mins, wipe it off with a white nylon scourer pad. Then use a clean wet microfibre cloth to rinse and wipe up any residual vinegar. The vinegar slowly dissolves the grout. Thats why you DON'T want it in the actual grout joints. It might take 2 or 3 goes to get it off. If this is not working altogether, the grout might have a latex additive. In that case, repeat the above, but use metho. Ash. Thanks splashers, that makes sense. The waterproofing guy used this Davco product, I will raise the issue with builder and hopefully get resolved with him - if not… 2 12892 Hi everyone, Have just put a shower in the laundry and after only using it 2-3 times have noticed staining on the grout. The tiles were glued onto a concrete wall after… 0 5449 I couldn't attached the photo for some reason. Here is the link to the photo https://pin.it/79jwdMp 1 3116 |
