Browse Forums Building A New House 1 Oct 19, 2009 6:13 pm Hi I've had a read of some great threads re planning Electrics and network points etc. and have a simple question or two. In the absence of not knowing at this early stage where our furniture will go, whether we will have wireless or wired ADSL, plans for the kids rooms, heating what can we reasonably do in advance that provides us with some flexibility to add post build? Thinking * gas point in Alfresco * Gas Outlets in Lounge, Family and Hall (if we go space heaters) * Conduits/draws in multiple locations where phone/network is most likely to go. I assume in this case that when we do decide we cut a hole, draw cable and pop on a face plate etc. So we won't put in the actual network cabling, just have the option. Maybe 2 ports (phone and network) in 2 locations in each room to allow for furniture moves * I assume for the above the main point is to determine where all the cable will go back to * Power halfway up the wall in case we decide to wall mount TV * Power high up in study for network equipment * TV points - do I also need to be specific and ask the TV points to * Power in the ceiling e.g. Alfresco * Alarm - never had before, what could easily add that would make it easier later? I assume the guy who does our Telephone points would do all the cabling stuff? Thanks Re: Electricals and Networking 2Oct 19, 2009 9:49 pm generally a sparkie will have their data ticket... but some of them barely understand the basicis of cabling let alone practical uses of said cabling... if you can geta third party data cabler who is good at TV stuff aswell Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10051 The HIA contract, in the term & conditions section states that "Commencment" is deemed when the drainage is started or the piers are dug or the slab is formed up (incase… 2 6183 Hi there, We've just build a new hardwood (Greybox) deck and am wondering whether firepit protective mats/surfaces are sufficient? I'm not sure that they're heat… 0 2118 |
