Browse Forums Building A New House 1 Oct 06, 2009 3:19 pm Hi all, I am currently in CC stage to building a torrens title duplex in Epping (Parramatta council) which was DA approved one months ago. I've hit road block in regards to subdivision boundary and windows. My duplex has a staggered design where right duplex is about is pushed back roughly 13m to allow for double garage for both sides. Because of this the subdivision line runs along the wall of left (front) duplex. My PCA has pointed out that any windows onthis wall will have to be fire rated as it is directly on the boundary. I've got several options according to my current PCA: 1. Install fire rated windows adding significant cost to construction. 2. Alternate solution by level 1 PCA, again a significant cost. 3. Redraw the subdivision line so that it is 900mm away from the wall. Which require section 96 approval at relatively lower cost. Any suggestions? Thanks in advance. Re: Boundary and windows 2Nov 08, 2009 6:46 pm Hi have you considered glass bricks? They have a good fire rating. I looked into them they other day for a boundary wall but my DA approval has no windows on bndry wall so decided againsts as i didnt want to deal with council S96. I know that sometimes they look a little dated but there are a few styles. I would prob put a fire rated window to avoid council again - time is money. Good luck. You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17168 ask the surveyor for clarification would be the logical approach 1 20144 just talk to them, tell them it is unsightly and ask them for a solution. Any reasonable person would render it for you or do something similar. If they give you trouble… 4 18823 |
