Browse Forums Building A New House 1 Oct 05, 2009 9:43 pm I got a phone call from SS today saying that we have an issue with our front door. Carpenter has just put on our front door as we have had a temporary door since lock up. And now that they've gone to put our handle and deadlock on, the carpenter and SS had some concerns as to how to make it all fit nicely. Our door - Corinthian Madison 104 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Handle that we chose - Gainsborough Horizon 600mm handle (one on inside and one on outside) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Lock - Gainsborough double cylinder deadlock in chrome Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Our SS made me realise that 1. since it's a double cylinder deadlock...it will drive me crazy as I will always need to have a key to open the door from the inside. 2. He's also doubtful that there will be enough room to have the handle and deadlock side by side half way up the door as the side panel of the door where all this goes is quite narrow....he feels that it will be difficult to open the door. 3. He also says that with the length of the handle....the lock will look funny if it is above or below the bar. I don't think that will look nice. -------------- So help!!!!! What should I do? Can it be done? Will my key problem be solved if I change my double cylinder deadlock to just a single cylinder deadlock? Can both handle and lock fit on the madison door? If you have any photos....please show me. I am curious to see if there is enough room to insert a key in the lock easily. Urgh!!!! TIA!!! Our building journey has begun: https://forum.homeone.com.au/viewtopic.php?f=31&t=23138 Brookvale 45 by Porter Davis ************** Lead me not into temptation.....I can find the way myself. Re: Front Door help needed URGENTLY!! 2Oct 05, 2009 10:04 pm intersting combination. I would suggest going for something like this: http://www.locksgalore.com.au/?page=sho ... eadlatches That would solve your problem with needing a key to open the door on the inside. if it was me i'd change the handle. Building Standards; Getting It Right! AS2047 Section 6 Page 31 speaks to Construction/Tolerances of Windows and external glazed doors in buildings Check also New South Wales Guide to Standards and Tolerances,… 12 24762 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8289 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9070 |
