Browse Forums Building A New House 1 Jun 25, 2007 12:48 am has anyone built the heywood 28 porter davis home and found they couldnt have a extended post formed benchtop in the laundry due to space restrictions? dont know why they offer it and then tell you ..you cant have it. has anyone found a way around the problem? Re: heywood 28 extended postformed benchtop 2Jun 25, 2007 1:15 pm Hi clath
We are buidling with PD also, and although ours is the Francis it sounds like we have the exact same problem. Our problem was pointed out to us after construction had commenced. Basically with the bench being in place it left a very small washing machine space next to the back door. This space would have only fitted a 5KG machine or front loader. We have a 7.5Kg machine so we had a few options to consider: *Make the back door narrower - ie 820 to 720 *Swap the washing machine space around from next to the back door to adjacent to the internal door. We decided to swap the space around, and the builders shifted the internal door space as far across as possible to give us the largest space they could. An option was to make the injternal door smaller from 820 to 720 but we did not need to do this. With the bench being swapped around I could see that it would be slightly too wide to fit next to the back door. They allowed for this by making it a 'banjo' bench (shaped a bit like the ones you see over baths). This look didn't worry us and solved the problem. Happy to say that with a large washing machine, there is plenty of clearance and we have managed to keep both the external and internal doors at 820mm. We thought that leaving the doors that width would make it easier walking in and out with a washing basket in hand. I just looked at your plan and you could swap the space around. Another option that they have now done with the Francis is move the bedroom wall back by 100mm. I think this could also work on the Heywood if necessary. Hope this makes sense? Send me a PM if you need more info as I don't have photo's of this yet. Tony extended postformed benchtop 4Jun 26, 2007 12:28 am thanks uncle ant for your helpful reply im having contract signing on friday ive prob left it to late to make any changes in regards to the extended laundry bench top otherwise i could be up for extra costs due to their variation sting, but anyway will try coz its worth having. by the way your house is coming along nicely been having a peek at ur blog ps if u can get a pic of ur laundry on ur blog it b great Re: heywood 28 extended postformed benchtop 5Jul 03, 2007 12:17 am Hi Clath
I know you have had your appointment already, but thought you may still like some before and after pics of our laundry. There are some update pics on my blog. Tried to put here but it was drving me crazy and getting too late to think straight! You can now see what I mean by Banjo Bench if you were unsure. Cheers Tony yep, clearly mark where the infloor heating pipes are before drilling or nailing 1 5449 |
