Browse Forums Building A New House 1 Jun 21, 2007 3:52 pm As I am waiting for the work on my frame to begin, the question I have is what is the minimum safe period of time that needs to pass for the slab to be ready to be built on? Two storey house is being built by the way.
I've been told a lot of different things about it which vary quite a bit. Some say you can start almost immediately, as the pine is very light and doesn't pose any danger for the slab. Some say a week or so break in between is best allowed. Whereas some say as much as 3 weeks are required. Any builders out there who can shed some light on where the truth is? Re: Time required between Slab and Frame stages 4Jun 21, 2007 4:22 pm I think PD seems to start frame pretty much straight away...Have seen others leave the slab for a couple of weeks - I think they left Matt W's slab for two weeks before starting frame. Built Porter Davis "Dromana" 2007. Re: Time required between Slab and Frame stages 5Jun 21, 2007 4:38 pm They did wait 2 weeks on mine.....
How long is right???? Re: Time required between Slab and Frame stages 6Jun 21, 2007 4:43 pm Curing - curing will help reduce surface cracking. Concrete typically takes 28 days to reach its design strength, and the first 3 to 7 days are critical, beginning as soon as finishing of the slab is complete. An applied liquid curing membrane is usually the most practical method. Covering with a plastic sheet will also work but is harder to maintain. Keeping the concrete continuously wet, while the best method of curing, is not advised due to the large amounts of water that may be required;
http://www.greenhouse.gov.au/yourhome/t ... /fs34f.htm Re: Time required between Slab and Frame stages 7Jun 22, 2007 9:40 am I think my builder said something about 3 day wait for frame and 2 weeks before bricks because of the weight of the bricks.
3xb Re: Time required between Slab and Frame stages 8Jun 22, 2007 10:46 am Well, my frame work has started yesterday afternoon (Thursday) after the slab was poured on Saturday. 5 days.
Hope it won't be an issue, but it does seems to be treated differently by different builders... Re: Time required between Slab and Frame stages 9Jun 22, 2007 11:34 am Never thought this would be something I need to worry. Will keep an eye on this when the construction starts, hopefully sometime before end of July...
Cheers Allan http://building-our-first-house.blogspot.com/ Thanks for your suggestion, but too late unfortunately. I went with Darbecca. They've done the pre-pour inspection and frame/slab inspection for me already. Been pretty… 26 11918 Yes, this is a huge thermal bridge which will more or less undermining the insulation already installed in the walls. Cold air will be travelling down from your under… 1 2390 We decided to have the dividing wall just above the waterline by 25mm, thanks. 2 8105 |
