Browse Forums Building A New House Re: Weephole above windows are the required? 2Aug 05, 2010 7:50 pm Hi Caroline...not sure if you're still around, but we don't have them above 90% of ours, our inspector says that's breaking the code. Flashings over doorways and windows our carpenter has installed flashings that is buckled and short of the window frames and door frames is this right Is there a… 0 10923 Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 20579 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11759 |
