Browse Forums Building A New House 1 Sep 26, 2009 4:48 pm Just wondering should the garage part of your slab be lower than the rest of the slab, so sort of "recessed"?? Ours is about to be poured and it looks like the garage is going to be level with the rest of the house. Im not that worried about it but im just curious to know if this is unusual or not. Re: Slab pouring - should the garage be lower? 4Sep 26, 2009 6:20 pm Mine is not lower, my SS says not many garages are lower anymore. When the inside is tiled my garage will be a tile thickness lower. Re: Slab pouring - should the garage be lower? 5Sep 26, 2009 6:51 pm buildingwithhamra Mine is not lower, my SS says not many garages are lower anymore. When the inside is tiled my garage will be a tile thickness lower. If the driveway sloped down to the garage I would insist on a step into the house, just in case there's a heavy enough downpour that the drain can't cope. I know of it happening to others. As for the tile thickness difference, wouldn't that be a tripping hazard? Re: Slab pouring - should the garage be lower? 6Sep 26, 2009 7:05 pm I agree with Macy. In all the builds I've seen in my area (Sydney metro area completed by project builders v custom) the garages are always lower if the site is on the low side of the street. That being said...the house opposite our site in Ryde (a M@sterton) is on the high side and its garage is lower too. There's probably some regulation/guideline about this somewhere Pix Built a (highly) modified Allcastle Maxworth 38.7 in Sydney. Re: Slab pouring - should the garage be lower? 7Sep 26, 2009 7:57 pm We are on a dead flat block and our garage is one step lower then the rest of the house. I thought in NSW it was regulation to have it for flooding / water damage purposes? Some things are worth waiting for. Re: Slab pouring - should the garage be lower? 8Sep 26, 2009 11:47 pm Quote: There's probably some regulation/guideline about this somewhere Not in SA Quote: As for the tile thickness difference, wouldn't that be a tripping hazard? Maybe for an ant... My front door jam is larger than this. Re: Slab pouring - should the garage be lower? 9Sep 26, 2009 11:56 pm buildingwithhamra Quote: As for the tile thickness difference, wouldn't that be a tripping hazard? Maybe for an ant... My front door jam is larger than this. That's the point, an obvious change in level/material is less of a hazard then a subtle uneveness. Re: Slab pouring - should the garage be lower? 10Sep 27, 2009 12:24 am i'm going to insist on a "sunken" floor in the garage... or raised main part of the house... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Slab pouring - should the garage be lower? 11Sep 27, 2009 7:55 am Hi suenmatt Im in brisbane and the garage slab is same level as rest of the house. It is a standard with my builder and most others i know of. Dont know if that is the case only for new houses. Rentals we have lived in have had garage one step lower. I dont mind either way. Just didnt want to spend money on upgrading. Re: Slab pouring - should the garage be lower? 12Sep 27, 2009 8:08 am Thanks everyone. Sounds like its not unusual then! Our block is elevated, with a nice slope to the front of it. There should be no issues with drainage. Re: Slab pouring - should the garage be lower? 13May 15, 2011 12:46 pm If your house is brick then the garage(& paths) will be -1C or 86mm lower( or 172mm for a 2 brick set down and multiples of 86mm ) Where you are coming from is where you are going to... Hi there, We’ve recently had plans approved to add a 1st storey addition to our existing house for a growing family in Sydney. With the current cost of building… 0 4298 I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an… 0 11377 i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 16026 |
