Browse Forums Building A New House 1 Sep 24, 2009 6:33 pm Which system did most people get....and why is one better over the other...??? The switch is a unit that when the tank runs dry, it switches to a mainswater bypassing the tank line. It is considerably more expensive. Toliets can be used when power is off. I guess when tank empty, less elect used by pump, less wear... The float unit is where when the tank level is too low, a float turns a tap on and the tank is filled above the desired reserve level. Tank always has water in it. Pump always used... toilets wont refill if power out... less space to refill with rainwater... So which one do people reccomend..?? Re: Rainwater tank - Switch or Float..? 2Sep 24, 2009 7:26 pm I'd hate to be dependent on power to be able to flush a toilet. Could get stinky if the power company is a bit unreliable. Ours is the kind with a switch - no idea about it being more expensive or not, that's just what our builder provided. Any electricians here please help. 1) Will the Fan need separate switch to ON/OFF/Speed eventhough it comes with Remote 2) how about… 0 1217 18 90494 DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31282 |
