Browse Forums Building A New House Re: Building Garage to The Boundry Wall 21Sep 21, 2009 6:10 pm Are you building next to an empty block by any chance? My problem was my neighbours have been there for 50 years overlooking my dads property and now they think they own the view. Not many people like change, and I guess building a house to obstruct their view is distressing for them, but they should be grateful they had an empty block next door for 50years, not many people could say that. I could only just imaging the uproar if I decided to build a two story!!! Re: Building Garage to The Boundry Wall 22Sep 21, 2009 9:09 pm buildingwithhamra Hi, I have build on the boundary, the gutter does not hang over your neighbours property. the design is different to the gutter with an eave. i will attach a plan for you. My council will not allow a house to be build 20cm from the boundary as it is a haven for rodents and a fire trap. buildingwithhamra has explained it perfectly. Of course your gutters can't hang over the boundary. In Craigieburn, the regulations will be the same as ours - you may build either 0m or 1m from the boundary, nothing in between. Any registered builder will be well aware of the requirements, so there should be no issue. Our garage is built to the boundary and so is our neighbours' (in actual fact, there's a small space between the two brick walls, but it's not even noticeable). Our spouting is exactly as shown in the drawing above. Here's a pic: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building Garage to The Boundry Wall 23Sep 22, 2009 11:28 am Of course your gutters can't hang over the boundary. In Craigieburn, the regulations will be the same as ours - you may build either 0m or 1m from the boundary, nothing in between. Any registered builder will be well aware of the requirements, so there should be no issue. Our garage is built to the boundary and so is our neighbours' (in actual fact, there's a small space between the two brick walls, but it's not even noticeable). Our spouting is exactly as shown in the drawing above. Hello... Thanks for your reply. I also want to build to the wall to save space but my friend put me in doubt. As you said its either 0cm or 1metre in Craigieburn. May I ask how you know the regulations in Craigieburn. Do you know someone who built home there or you think these are standard regulations. thanks Re: Building Garage to The Boundry Wall 24Sep 25, 2009 12:29 am tandyg77 Ring your council, ask for a town planner they will tell you within a minute, whether you can build 20cm from your boundary. In my council I can build on the boundary or over 1m from it nothing in between. How big is your block and how big is your house? Mine is only 10m wide so I really had no choice but to build on the boundary. Re: Building Garage to The Boundry Wall 25Sep 25, 2009 7:32 am tandyg77 As you said its either 0cm or 1metre in Craigieburn. May I ask how you know the regulations in Craigieburn. Do you know someone who built home there or you think these are standard regulations. I just know the area and the building regs for new estates around here are generally the same. There can be variations in established areas, but 0-1m side setback is the norm unless you have easements or the like in the way. I can't see any reason why you'd have a problem... your builder will know the requirements, plus your plans will have to be lodged for building approval (and possibly developer approval) anyway, so there's no way a mistake like that would get through. Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5196 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17202 thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 16294 |
