Browse Forums Building A New House Re: Could I install a satellite on easement 2Sep 18, 2009 3:56 pm are you prepared to shoulder the cost of "move it and put it back" when they need access to the easement? i heard you can even build a vegie patch over easement but should always be mindful of when they need access ... vegie patch or satellite? no diff maybe. Re: Could I install a satellite on easement 3Sep 18, 2009 4:22 pm http://www.gleneira.vic.gov.au/Files/BO ... n_Pack.pdf http://www.greaterdandenong.com/Documen ... r+Easement http://www.melbournewater.com.au/conten ... asp?bhcp=1 A couple I found to give you some more information. Best people to ask would be your council. ---------------------------------------- Building the PD Lisbon 24 http://www.porterdavis.com.au/#homeviewer/lisbon/24 Blog of our progress. http://lisbon24.blogspot.com/ Homeone build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=28665 You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17163 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16146 Thanks - yea sounds like I need to submit build over easement application....ugh guess I better start finding someone who can do the engineering drawings 3 3361 |
